Results 1 to 10 of 45
- Apr 2008
- 27
September 4th, 2008 01:15 PM #1Mga Sir,
My Car is a Hyundai Accent 2000 sedan.
HU: Pioneer DEH-P2650
Front:Boschman seperates (5 1/2)
Back: Sony 2 way 160W (6 1/2)
Trunk:Sub Powered NBN 8 Inch
Medyo hindi ako happy sa Sony, would it be good if i put seperates also in the back? do i need an amp to drive my front and back speakers? Low budget lang ako. my goal is a nice clear sound lang not on the bayo side
Thanks
Patrick
September 4th, 2008 01:46 PM #2
sir if understand correctly, walang amp na drive yung seps mo sa harap... if you want the clarity... amp is the solution. kahit v12 lang ok ka na. sayang lang yung sub mo sa likod kasi parang built in na yung amp. hindi po talaga nakakasatisfy subs ng ganon.
pero just to give it clarity, low powered amp lang for the front ok na... wag na po yung likod. ok na yan.
hth
- Jan 2008
- 152
September 4th, 2008 05:19 PM #3try ditching the sony speakers at the rear.
kung hindi pa rin maganda, install an amp for the seps
September 4th, 2008 08:08 PM #4
save for an amp muna, fenton or v12. kung kaya pa jbl amps, mura na lang brandnew nito ngayon.
September 5th, 2008 02:11 AM #5
September 5th, 2008 12:14 PM #6
^^ pwede po... 2 channel for the seps and mono amp na lang for the sub.
kaso parang no point yung ganon kung kaya naman ng isang amp yung setup. the only reason two amp set up yung iba is because kulang yung wattage ng amp to power the system.
edit: ay oo nga pala, mas mahal din lalabas yung setup kasi dalawang power supply cable kakailanganin mo. hehehe
hthLast edited by archie123456789; September 5th, 2008 at 12:17 PM.
- Apr 2008
- 27
September 5th, 2008 12:21 PM #7Thanks for the advice mga sir,
Ill defenitly get a V12 or Fenton, and if i have a budget ill go for a jbl.
Would it be good if i put seperates also sa likod? Im thingking both front and back seperates powered by one amp?
Patrick
September 5th, 2008 12:29 PM #8
^^ pwede rin power ng amp both seps and rear kaso no point if your going for staging effect kasi masasapawan din naman yung rear ng subs.
pero ok lang naman...
- Apr 2008
- 27
September 5th, 2008 03:01 PM #10
sir if your willing to spend a little more money, get rid na lang of the subs and get a decent 12" (boxed) and an amp na 500 watts rms. hayaan mo na yung rear speakers to be run by the HU... power the seps and the subs sa amp.
this way mas maganda lalabas na tunog.
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
