Page 3 of 7 FirstFirst 1234567 LastLast
Results 41 to 60 of 122
    #41
    Yes sir. Sa tsikot shop tinuturo ng tao ko kung paano hihiwaan ang deadening pad just in case may aayusin. Thats why its important na magtanong din po sa installer.
    #42
    Quote Originally Posted by jedi View Post
    ah ok... thank you sir. balak ko kasi magpalagay nyan and yun ang nakita kong problema, may paraan naman pala. cheers to tsikot shop.
    #43
    sir, what is the material of your sound deadener?
    #44
    Ano po ang thickness ng sound deadener and insulation ninyo???
    Oct 2009
    #45
    good am! mine is an old isuzu hilander with basic sound setup only... my concern really is on the rattling noise of its doors... matanda na kasi siya... will deadening lessen the rattling noise... TIA
    #46
    had deadening installation c/o tsikotshop... big improvement both sa NVH and sa tunog ng sounds.
    Jon of Tsikotshop installing outerskin deadening...
    #47
    Mag kano pa lagay mo at gano katagal ginawa?
    Jul 2012
    #48
    Hi sir. do you recommend sound deadening for a 2009 montero? will it have an effect considering the loud diesel engine humm? thank you sir. And where is tskiotshop? ive been hearing about it but i havent the slightest idea where it is in taguig. bgc lang po kasi ang alam ko sa taguig, would very much like to visit the shop.
    #49
    *nelany... around 6sheets ata nagamit at 550pesos per sheet... around 3hours siguro inabot.
    *jazz799, tsikotshop is along east service road.. near sales bridge.. kahilera ng TESDA. check mo sa google maps lalabas ang exact location
    Dec 2011
    #50
    Sir Jedi,
    Ask ko lang po kung pwede magpa re-route / re-wiring ng sound setup ng strada ko and how much ang labor. Mag papalagay na rin ako ng door sound deadening sa 4 doors and how much it will cost. Complete equipments na ako sir. Na setup na sound system ko sa Isabela pero magpapalit ako ng speaker wirings and rca cable (monster xtra low noise materials).
    Many thanks.
    Dec 2012
    #51
    What is the weight of this material per sheet?
    Aug 2010
    #52
    any idea kung saan makaka bili ng sound deadening? or saan meron nag iinstall?
    price?
    Aug 2010
    #53
    A lot of car audio shops sell MLV sheets and also offers installation. Price per sheet varies between brands but each sheet costs around 500 pesos.
    Apr 2012
    #54
    Quote Originally Posted by trucker111 View Post
    price?
    most of the car audio shops offer and install them. check mo rin ang tsikot shop, may offer package din sila niyan...
    Aug 2010
    #55
    Quote Originally Posted by jhnkvn View Post
    will deadening help improve the sound quality assuming all set up (hu, speakers) is stock?
    Aug 2010
    #56
    The most apparent use of road deadening sheets is to reduce the amount of road noise. And as noise is typically in the bass region of 200hz, quieting that down gives the user "uy, nice bass!". A very good analogy for this is the seal of earphones. Have you ever tried your typical Apple earbuds versus those that are IEMs? You will notice that everything's "fuller" once you have a good seal on your ears and this draws you to enjoy your music more.
    There are actually three types of deadeners: CLDs, MLVs, and CCFs. We're most familiar with MLVs or mass loaded vinyls (usually, shop installers know them as "butyl sheets") because it's the most inexpensive alternative to lead that blocks sound. Aside from blocking the sound via its mass/density it also lowers a panel's resonant frequency. As for the others, CCFs are closed cell foams and is used as a decoupler and CLD sheets on the other hand are used to lessen the vibration around the cabin. Visualize a thin sheet of metal and you hit it... it'll go "tinnggggg", what the CLD does is lessen the decay of the sound so you hear the "ting" for just one second versus three. As a less expensive alternative, you can create your DIY CLD sheets by buying a MLV sheet and cutting it into small pieces then pasting it all over the car.
    Will it help? That depends. As different cars adapt differently to deadening. The advantages of deadening a Merc versus a Kia Pride is huge as an example. However, if you are going to deaden, go for the doors first then the flooring as these two contribute the best bang-per-buck in vehicle (floor) and sound (doors usually).
    All I can tell you is that two things:
    1. I've never seen a professional car audio event contestant without deadeners.
    2. I've never seen a noisy car win car audio events. This is the reason why walang nananalo na Isuzu Crosswind
    Apr 2013
    #57
    Do you know any shops that offer the product and installation services here in Quezon City, and I assume they also install in speakers, yes?
    Aug 2012
    #58
    2 sheets po ba ito per door or isa lang?
    Aug 2010
    #59
    *respi
    Just drop by Banawe Street and you'll literally find tens of them offering speaker installation services. However, deadening is best done by more specialized car audio shops such as Candyshop, Jetcars, Maspro, Dawg Audio, etc.
    Aug 2010
    #60
    Quote Originally Posted by chard23 View Post
    That would differ from car to car basis. The bigger the car, the more sheets. Also, it depends on how much deadening you would be applying. Remember that your door has the inner panel and the outer panel. A fully deadened door might consume 3-4 sheets per door in fact.
Sound Deadening / Deadener Tips
