Results 1 to 2 of 2
December 2nd, 2005 03:27 PM #1
What are the differences and their power requirements? Example, if i have a mono amp rated at 500W x 1 * 4 ohms, what would be the actual power output & impedance on a single SVC sub? on a single DVC sub?
Tsikot Member Rank 4
- 2,719
December 3rd, 2005 04:10 AM #2Originally Posted by swordsman
1) You may use the amp on a SVC sub with coil rated 500W * 4 ohms.
2) You may use the amp on a DVC where each coil is rated 250W * 2 ohms, with the coils connected in series.
3) You may use the amp on a DVC where each coil is rated 250W * 8 ohms, with the coils connected in parallel.
Eto nalang gawin, kunin starter relay at fuse pump habang ginagawa pa yung key fobs. ...
