Results 1 to 10 of 15
May 18th, 2006 02:58 PM #1
kapag nilakasan ko yung sounds ko...yung speaker sa likuran, parang basag ang tunog. may vibration. di ba compatible ang HU ko at speaker ko??
May 18th, 2006 03:13 PM #2
distortion tawag dyan, underpowered ang speaker mo, which is very common dahil maliit lang naman amp ng HU eh...
May 18th, 2006 03:23 PM #3
paano ko malalaman ang amp ng HU ko? at amp ng speaker ko? base on sticker, label etc.
tnx
May 18th, 2006 03:36 PM #4
walang amp ang speaker, ang amp ng headunit, built-in na sa board ng headunit... ano ba model ng radyo mo? usually nasa harap nakalagay na yung max wattage ng radyo.
May 18th, 2006 04:05 PM #5
usually around 35-60 watts lang. depende sa unit. sana nag-active subs ka na lang.
May 18th, 2006 04:13 PM #6
Ganyan talaga, when your speakers don't get enough power it will clip / distort.
Time to add an amplifier and aftermarket speakers...
May 18th, 2006 04:38 PM #7
...either those or the coil/driver of your speakers are have begun to burn (sunog - kung baga may sayada na). You can do the following quick test to determine if the coil/driver has began to burn:
- Remove the cover of your speaker.
- Gently push the speaker cone up and down ('bout half an inch or so)
- Repeat the same process using by gently pushing up and down around the outer cone in a circular motion
Dapat pino ang laro nung cone. Kapag naramdaman mong medyo magaspang na and/or may naririnig ka nang gumagasgas, it's possible sunog na ang coil ng speaker mo. Either kailangan mo ng bumili ng bago or ipa-rewind mo.
May 18th, 2006 05:37 PM #8
try ko mamaya yung pushing technique...
kung halimbawa 35-60 watts ang headunit ko?? dapat ang speaker ko eh ilan watts??
