Results 1 to 5 of 5
    mga sir tulong naman po...ung nabili kong second hand na 2003 lancer GLS walang sound ung rear na speaker...2 piece un...stock po ung head unit ko...bakit po kaya? thanks po...
    Quote Originally Posted by sum1_27 View Post
    Could be a lot of things from simply not being connected (loose wiring) to busted headunit (faulty rear-speaker output).
    Best to bring it to a car audio shop to let them have a go at figuring out your car audio problem.
    check also the settings of your Headunit. maybe naka off lang ang rear speaker or check the speaker positioning adjustment sa HU.
    Quote Originally Posted by s_quilicot View Post
    2x ...1st thing to do before you go to shops it could be simple setting that went off. Baka naka fade lang ang rear speakers.
    Oct 2003
    Check the following
    1. speakers dead
    2. wiring to speakers
    3. settings sa head unit
    4. faulty head unit
rear speaker walang sounds...
