guys now i'm starting to get really curious about car audio systems...
for starters, i have a bunch of questions about amplifiers. pero isa-isahin ko lang po para mas maintindihan ko (pati ng ibang newbies) mabuti... please, i need enlightenment.
anyway... simulan ko na po...
do amplifiers generate more heat pag mas nilalakasan ang volume ng music, lalo kung ma-bass yung track?
[sIze=1]takot pa kasi ako kaya di ko masyado nilalakasan volume...[/sIze]
san pinaka-safe ilagay ang amplifier? sa trunk ba talaga dapat?
[SIZE="1"]sa ngayon po kasi, mine is situated under the driver's seat para kahit pano naaabot parin ng aircon o kaya pag off aircon at bukas windows, may ventilation parin. tama po ba naging decision ko?[/SIZE]
yan po muna guys. need some answers/advice po.
thank you!
place your amp on a well ventilated place en di mababasa!!!
you can place a fan if you want too.well under the seat is safe,kung di masisipa ng passenger sa likod! especially the connections!!!
pero pinakasafest place kung san magandang imount ang Amp?? here is the situatuation, its kinda raining, medyo bumpy ung ride, pero naka sounds ka pa rin na boom boom, xempre magiinit ung Amp, is it really safe to place it under the Drivers seat? pero parang gus2 ko is under the Glove Compartment kaso problem naman is kung panu kung magpapalinis ka ng Aircon, kalas na naman un, Or, sa dashboard mo sa likod (dun sa pinaglalagyan ng mga 6x9's mo, sa gitna nun, pwede kaya dun? hindi naman kaya maiinitan un, pag naarawan??? pero lagay na rin natin ung scenario na naka Dark Tint ka, Super Black or Chrome black magic tint....
I've had amp mounted in the trunk and in under the seat. Both are perfectly fine. Both have advantages.
I prefer amps under the passenger seat. Reason, shorter wire runs. In other words, less expensive. And the AC keeps the amps cooler. Just make sure its securly mounted, it wont move around. If you will mount it under the seat, make sure water does not enter your car when crossing floods. And as previously mentioned, it wont get steeped on or kicked by passengers.
For trunk mount, you have more room to work with. You can show it off. You can have a bigger amp. Of course, longer power, speaker and rca cables.
