Results 1 to 4 of 4
- Jul 2005
- 122
February 2nd, 2006 01:46 PM #1Greetings tsikoteers, need help on my radio. pag naka-on na ang headlight nagkakaroon ng static ang radio, pero during daytime naman ok bec di pa ako nag-on ng headlight. nagpalit nako ng HU pero ganun parin. Ano kaya ang solution dito? by the way, my HU is pioneer 2850, ae92 car. Thanks in advance.
February 2nd, 2006 02:18 PM #2
replace your headlight.....
kidding aside, redirect your fused positive wire to the battery positive terminal and the power on wire to the ACC and not the IG of the ignition switch. This is what i know unless there is a new way of connecting it.
February 12th, 2006 09:29 PM #3Originally Posted by duncan_sheek
since the ae92 is quite an old car, try checking stereo ground and the body grounds of the vehicle. insufficient grounding can cause static and power loss sa electrical systems.
whining sound comes from the alternator.
February 14th, 2006 12:18 PM #4
maybe you can get yourself some inductor chokes to clean the power line ;-) kung may naitatabi kang ferrite materials diyan, wound the power line around it lang
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
