Results 1 to 7 of 7
February 14th, 2007 05:45 PM #1
How do I improve the radio reception of my car stereo?
Do I install an aftermarket antenna?
Are there aftermarket thingy I have to buy and attach to my stereo?
Nangyayari kasi kapag nag scan ako ng radio stations, marami sya ini-skip na station. Like for example kung minsan ma-detect nya 92.3 FM minsan hindi. Kung minsan naman okay lahat. Tsaka yung AM stations, kaunti lang nakukuha ko. Dito yan ah sa Metro Manila hmm....
Saan kaya problema nito?
February 14th, 2007 05:53 PM #2
Pls check first the car antena and plug-in cable. Baka corroded or me crack na kung luma na OEM car stereo. I have a similar problem with my xwind antena before meron crack sa base kaya mahina signal.
February 14th, 2007 06:55 PM #3
Meron bang setting na LO/Local o DX/Distant sa stereo? Baka naka-set sa LO (weaker reception, less interference).
February 15th, 2007 08:16 AM #4
Straight6, it doesn't have that feature.
XUV-AT, I will check on that. But my stereo is still a bit new, around almost 2 years old pa lang yata but will still check on it.
thanks, keep the suggestions coming.
February 15th, 2007 08:22 AM #5
Check the connections to antenna. Yung sa akin pag FM, I don't raise the antenna anymore.
February 15th, 2007 08:25 AM #6
February 15th, 2007 09:22 AM #7
Paki-describe na lang yung OEM antenna. Is it telescopic or is it a s/s whip or rod made from fiberglass? Is it vertical or can it be adjusted to tilt? O baka windshield mounted made from copper flashing? Daming tanong
With more info, I hope we can give you the right answer/s on how to check the antenna system. Of course, there is that possibility that there's something wrong with the receiver's RF preamp.
Xiaomi E-Car
