Results 1 to 20 of 49
Threaded View
    yun mga 500w maingay dahil sa cooling fan. i have a feeling hindi 500w yan hehehe. also make sure your 12v socket can provide enough amps baka matrip yun fuses.
    Dont plug a 500w inverter into your cigarette lighter. You will blow the fuses. Thats what happened to me when i was experimenting with ny ps4 setup in the car. You Will need to attach it directly to your battery.
    Most cigarette lighters can only give out 120W. On some cars this is written on the socket covet (12V 10A).
    is that 500 watts of PMPO, or is that continuous rated output?
    the numbers should be in there somewhere.
    just look for it.
    because if it came with cigarette lighter plug...
    salamat sa inputs mga bros, mabuti nalang di muna ako bumili agad (malapit lang sa office isang store nagbebenta)
    for mobile phone and laptop charger lang sana, wa epek kasi mga rated 2.1 or 3amps na car charger at malakas parin mag drain habang nasa byahe (waze, gps and data plus the screen)
    eto nalang in-order ko para free shipping :D
    https://shopee.ph/150W-Car-Power-Inv...7120.584045238
    https://shopee.ph/Car-Mobile-Convert...7120.573102112
Power Inverter
