Results 1 to 15 of 15
    Apr 2006
    Mga masters ano ba mas maganda gamitin na box para sa sony explode sub na 12"....ayaw ko sana nung umuugong na bass...mas gusto ko yung parang minamaso ang dibdib although kahit di ganun kalakas...yung medyo tight sana ang sound...thanks!
    Oct 2007
    try abc or sealed box.
    snail shell paps. boom boom yun!
    Dec 2007
    Quote Originally Posted by rtp View Post
    I would recommend a Sealed Enclosure. mas deep at buo ang bass pag sealed, kahit na single 12" ang sub.
    coz I have two 12" Kicker's on my Ford Aerostar van on Sealed enclosures, and they sound perfect! specially if the vehicle is an SUV or a Van.
    aite, peace.
    Dec 2007
    70% of your sound of your sub woofer is due to the design and build quality of your sub enclosure. When picking a sub woofer box, deciding to either go sealed or ported will determine how your system will sound.
    Sealed sub woofer boxes tend to be much smaller than ported enclosures, since they use the air inside the box as a spring for the enclosure. If you don't have much space, it would be a good idea to go with a sealed box. Not only is there a size difference, but there's also a difference in sound compared to a ported box. Generally the larger the box gets the lower the tone of bass is achieved. However if the box gets too large the "spring" effect that the air creates may be lost losing on loudness and crispness. Sealed enclosures produce tight, accurate bass and have a flat frequency response curve. They are the enclosure of choice when quality is the ultimate goal of the system set up.
    Ported subwoofer boxes can get very large and have many varying factors that will determine their size and bass output. For example the port has to be relative in size to the boxes volume depending on how much loudness vs quality is desired. Ported enclosures create louder bass than sealed enclosures, and allow you to tune the box to a specific frequency to determine how the bass will sound. Higher tuning on a ported box will get louder, but you will ose on sound quality. Lower tuning will still get louder than a sealed box, and at the same time deliver good sound quality. Generally this is a box for a set up where "boom" is the ultimate goal. Port area plays a major role in these types of enclosures. Too little a port area can result in port noise, which can severely detract from the sound quality. However, if your goal is to get loud bass and you don't care too much about the sound quality, a ported box, tuned high, with a large amount of port area is the way to go.
    ...read the full guide with pics here
    May 2007
    A very nice post.
    I was reading this forum all along but never read any post how to construct a good enclusure(box). Some people think that any box will do with thier system and that is a very deceiving...false.
    Some people know that an enclosure(box) does more than simply hold the subs on place, wrong....it is an integral part of the system. Believe it or not a properly sized and built enclusure can turn an INEXPENSIVE woofer into a good performer, while a poorly designed or constructed enclosure wiil make even the finest woofer sounds like mud.
    There are two main challenges in designing and constructing an enclosure; making sure it contains the proper volume of air, and controling the cabinet resonances that will otherwise compete with the sound from the woofer(subs). See jimmayor07 post how your sound become color if your box volume is incorrect.
    The ideal volume of an enclosure(lenght x width x height) will vary dependi kung anong woofer(subs) ang pinili mo. Hindi lahat ng woofer(subs) ay created equal they have diff., power range, frequency range, impedance and some have dual voice coil(DVC). You must know what is the right internal volume for your woofer(subs) to maximize the sounds w/o muddying the sounds either sealed or ported box.
    Your car system installer can help you how to choose the right box for you. If you are hessitant with your dealer or not sure, ask second or even third opinion from previous experience.
    Dec 2007
    Very helpful. Yun pala yung pinagkaiba ng sealed at ported boxes.
    From what I see the very short summary is
    SQ = sealed
    SPL = ported
    Aug 2006
    Quote Originally Posted by v6dreamer View Post
    A very nice post.
    Very well said nice!!!
    X2 and two thumbs up!!!
    Aug 2006
    Sorry wala po ako alam sa mga sony subs eh
    afaik this comes together with a recomended box manual dito ka nalang mag base!
    ived rather go with a sealed enclosure
    Dec 2003
    sealed for sq...
    May 2007
    KBR is right. Go with sealed box, used (0.95 volume cu.ft sealed box)
    Dec 2007
    mga sir question lang pano kung sealed yung box ko and i want to modify it lagyan ko ng ports? ok lang po ba yun?
    Jan 2008
    this is true...i've tried both ported and sealed enclosures...i chose to stick with the sealed enclosure...it will give you quality sound w/o sacrificing the "boom" ...
    Feb 2004
    ports should be calculated carefully especially knug lalagyan mo yung sealed box. afaik pwede basta tama ang computations.
    for sealed enclosure, you can get, yes, tight accurate bass. but if you want loud bass using this enclosure, get a very powerful amp.
    Dec 2007
    Quote Originally Posted by mmanson View Post
    pano po i-compute yung port para sa sealed box sir?
Ported vs Sealed Box [MERGED]
