ah,.. magkano naman ung cassette adapter at power adaptor or fm transmitter... maybe later nalang ung auxiliary input... bigay nyo naman po mga specs nun.. tnx...
ah,.. oki.. where should i connect those things,, cassette adapter & power adaptor,'' ung cassette adapter ba eh sa dating saksakan nung cassette player...
Cassette adaptor: cassette goes inside the cassette din of the HU. The male plug at the end of the wire goes to the female (earphone) socket of your HU.
You need to look at the power rating of your discman i.e. amperes, wattage,voltage et al. You need to get a power adaptor that can supply the proper..."level" of power to your discman. Too much power/voltage, you'll fry the discman. Too little, the discman won't work. You need to buy a power adapter that can offer variable voltage/wattage settings and changes in polarity setting.
As for where the adaptor goes, simple: one end goes to the cigarette socket while the other end goes to the power socket of your discman.
