Results 1 to 4 of 4
May 12th, 2017 02:26 PM #1
May 12th, 2017 04:06 PM #2
Am using that amplifer (KD80.4).. actually I had it removed just hours ago kasi back to stock set-up ako.
If budget meal lang yung sounds, i know the amp will suffice. Pero if you can add a few more pesos, get the lightning lab equivalent which makes no grounding noise. Nalalaman ko may tumatawag saakin kahit silent phone ko kasi may grounding sound sa speakers (tururut-tururut-tururut)
Sa seps, kung gusto mo naririnig ng mga katabi mong kotse yung sounds mo sakto siya sa purpose. Medyo harsh kasi tumunog sa totoo lang yung Kinetic seps. Kung habol mo yung tono, get the Teac CS6 which i used before installing my pioneer seps. The CS6 for me produces 7.5/10 (YMMV) of what my pioneer seps can do.
Pero as they always say, sound is subjective which means that yung bad sounding para saakin, it may be good pala para sayo and vice versa.
Just my 2 cents based on my experience on budget meal sounds.Last edited by Sleepcare; May 12th, 2017 at 04:52 PM.
May 13th, 2017 07:21 PM #3
1. It's a rebranded China goodie. Set your expectations there.
2. Same lang mga amplifiers niya sa price range niya really. In fact some of them probably came from the same factory.
3. Will just remind you that "grounding noise" is usually due to installation error. If not, it's a defect from the unit itself (which you can then send for warranty). Pare-parehas lang performance ng mga yan.
4. Speakers are the determining factor on how you hear your sound. The amplifier's "flavor"? A lot less.
May 15th, 2017 09:41 AM #4
3. Probably the latter... Kasi yung nauna kong LL amplifiers no grounding issue naman. Plug and play lang nung pinalitan ng Kinetic. Pero hinayaan ko nalang kasi "I got what I paid for", magrereklamo pa ba ako.
4. Very true like in my case it was Pioneer seps (Viet made)>china seps+china amp. I really said to myself na dapat tinetesting muna bago bilhin kasi I thought na basta amplified yung speakers it will sound better kaya ayun na-doble pa tuloy gastos.Last edited by Sleepcare; May 15th, 2017 at 09:46 AM.
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
