Results 1 to 6 of 6
Delicious
- 335
April 19th, 2004 10:00 PM #5
eto pala po, ngayon ko lang nakita sa web site..
Features:
MOSFET 50W x 4MAX.
PAL/NTSC compatible
DVD-Video Playback [ Glossary ]
DVD-R/RW [ Glossary ] playback (video format)
CD-R/RW playback
Built-in MPEG 2/1 decoder
MP3 playback [ Glossary ] with ID3 Tag*
5.1-ch. processor control (DTS/Dolby Digital/Linear PCM)
MPEG Audio decoder
96kHz/24-bit DAC (for audio)
10-bit video DAC
EEQ [ Glossary ]
> SFEQ (Sound Focus Equalizer) [ Glossary ]
> 5-mode preset equalizer
> 1-mode custom preset equalizer
> 3-band parametric equalizer
> Selectable electronic loudness
> Digital listening position selector
> 2-way crossover: HPF/LPF
Pop-up rotary volume [ Glossary ]
Direct Sub Drive
IP-Bus input
2 RCA preouts [ Glossary ]: selectable (front + subwoofer/front + non-fading)
A/V outputs
> Optical digital output (for DEQ-P7050)
> 1 RCA Audio output (rear)
> 2 RCA Video outputs (front + rear)
Multi-channel processor (DEQ-P7050) control
External unit control via IP-Bus (2 units)
AUX-In (with optional CD-RB20)
Level Indicator
SupertunerŽIIID
Dual-zone (two different sources) operation for front and rear
Multi-CD control
* With CD-ROM and CD-R/RW discs.
high idle RPM at engine start
