Page 1 of 2 12 LastLast
Results 1 to 20 of 39
    May 2005
    I just bought a Pioneer 2750 mp3/cd player at gusto ko sana siya i setup..I heard na hindi na raw ito pwede lagyan ng amplifier..Gusto ko sana gumanda sound ng auto but with reasonable price lng..Help nman mga people
    huh? di pwede lagyan ang amp?
    Quote Originally Posted by radiskull0415
    huh! may pre-out yan eh, paano magiging di pwede, whoever told you that is full of ****.
  4. #4
    A setup without an Amplifier is like a Car without gasoline... you need the juice provided by the amplifier to drive the speakers. Whoever told you that is either dumb or is pulling your chain...
    Quote Originally Posted by ILuvDetailing
    that's what i think so too.
    May 2005
    thanks for the info ....so how would i start? ano ba una ko install?san ba mganda audio shop? ung mura lng pero ok
    ano budget?
    Jan 2004
    As long as it has RCA pre-outs puwede yan... or kahit wala, just get an amp with speaker level inputs or get a line output converter... The 2750, rear preout lang yata, tama ba? Wala kasi akong makitang specs sa net...
    May 2005
    in terms of budget cguro hindi ko muna sabay sabay papa install, unahin ko ung pinaka importante at una dapat install,,newbie tlga ako pagdatin sa mga kotse kaya mejo inosente...ampli ba muna? ano un dapat ba pioneer din? o pag nagpalagay ako ng ampli ksama na dapat speaker? ung nsa oto ko ata nsa 100w ung rear....sa speaker ba it wud occupied space dun sa trunk? thanks sa mga replies...
  10. #10
    yung 100w na nakasulat sa speaker is the Peak Power Output. malamang mga 50Watts RMS (meaning constant power output) lang yan.
    Get an amplifier and front separates, am an SQ guy so unahin ko yung seps or If you love your bass get a Subwoofer. If your on a budget get one of those V12 amplifiers, madami sa raon, last time i checked their latest model costs around 4K (5-channel good for SQ).
    Jan 2004
    Let's check out what you have. So you have the 2750, and what are your existing speakers? Personally kung ok naman pa tumunog yung speakers mo lagyan mo ng sub + amp para magkaron ng bass. Pero kung basag na speakers mo or tunog lata, front separates na + amp.
    baka di kayanin ng stock speakers kung i-amplify dahil yung peak niya would be lower than the peak or rms of the amp. just properly mix and match your components, and you should be ok.
    Mar 2005
    how much would your budget will be?!
    May 2005
    ok pa nman tunog nun speaker so pede pla ako palgay muna ng ampli tpos sub,san kya shop mejo reasonable at friendly? ano ba ampli at sub na mejo mura? at san shop?
    Jan 2004
    What's your budget sir?
    Have you considered pre-owned? Dami sa www.kotseaudioclub.com... you can get a bargain on 2nd hand stuff...
    May 2005
    hindi ko pa rin alam budget ko basta paisa isa lng muna install kasi nsa shop pa rin oto ko for washover...ano ba pinaka reasonable ? hindi nman pinaka mura hindi nman masyadong mahal basta ok ung sounds pero hindi nman ung sinasabi nilang boom boom basta ok lng ung sounds...i hope u understand what i mean...thanks pal
    Jan 2004
    So you are probably looking for SQ, sound quality. Maganda ang tunog sa loob ng car, not necessarily rinig sa kabilang kanto.
    The reason why you need a budget is because you can spend anywhere from 5T to 50T just for front separates. Same with an amp...
    Many times price comes with quality, but you can also get pretty decent sound out of low cost stuff. Lalo na kung di ka naman sasali sa contest...
    May 2005
    I think mas ok mura lng pero very reasonable at ok ung sounds not necessarily superb basta mganda sounds nun oto within the car...pls give me an estimate ung pinaka murang amp at subs but ok ung quality no like proline type
    May 2005
    dd c1 (2 channel amp)
    100 watts rms x 2 * 4 ohm, 150 watts rms x 2 * 2 ohm, 320 watts rms x1 * 4ohm mono
    dd c2 (2 channel amp)
    150 watts rms x 2 * 4 ohm, 225 watts rms x 2 *
    2 ohm, 300 watts rms x 2 * 1 ohm
    475 watts rms x 1 * 4 ohm mono, 600 watts rms x 1 * 2 ohm mono
    dd c4 (4 channel amp)
    front: 75 watts rms x 2 * 4 ohm, 125 watts rms x 2 * 2 ohm, 260 watts rms x 1 * 4 ohm bridged
    rear: 150 watts rms x 2 * 4 ohm, 220 watts rms x 2 * 2 ohm, 450 watts rms x 1 * 4 ohm bridged
    dd m1( mono amp)
    600 watts rms x 1 * 1 ohm
    dd 1000 series
    high quality * low price
    svc 4 ohm
    300 watts rms/600 watts music
    1200 watts max
    8"/10"/12"
    alin ba ok d2 na mura lng?
    pricey mga DD pare.
    if you're really budget but not brand conscious, i'd get a fenton FA41000 amp. mga 6-7k sa raon.
Pano ko setup sounds ko?
