Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
    May 2005
    #21
    ok ba yan pare? bgyan mo nga me ng estimate kung papainstall ako ampli ska sub or pwedeng ampli muna...sa ampli ba mag improve ba agad ung sounds ko? or kelangan palitan ung speaker kc bka nd nya kayanin ampli?
    Jan 2004
    #22
    Check mo yung speakers mo kung ilang ohms tsaka ilang watts ang kaya, RMS at peak. Based on that masasabi natin about powering them with amps. Pero sub + amp na lang muna since sabi mo ok naman ang speakers mo. Mga 25K puwede na, sama wiring, fuse, sub box tsaka simpleng install.
    Jul 2004
    #23
    Pasingit lang. Kailangan ba talaga sub for SQ?
  4. #24
    Pre, Pricey yung DD, kung may makita kang 2nd hand baka pwede.
    Amplifier naman kung tight budget ka, kuha ka ng V12.
    Jan 2004
    #25
    Quote Originally Posted by Field Master
    Depende... the goal really is to have a good response for the full range of audible frequencies, and 20-100Hz can be reproduced better by large drivers.
    Now if your music rarely hits below 50Hz, baka kaya na ng 6x9 sa likod yung lows... And some seps can play 80Hz with about the same level as higher frequencies, plus you can always adjust the gain for these frequencies if you have an EQ that can adjust those frequencies.
  6. #26
    Pwede but whats a sound system without subs. You'd appreciate the song more if you hear those lows, lalo na mga with Ambrosia, Earth Wind and Fire, Clair Marlo songs.
    Dec 2003
    #27
    Quote Originally Posted by ILuvDetailing
    yep ok V12 but beware of the ULTRA FAKES..grabe mura 3k+ lang pero grabe rin uminit haha
    Jul 2004
    #28
    Wildthing, ILD, thanks for your guidance. will get in touch with you when I upgrade my sounds.
  9. #29
    Quote Originally Posted by BlueBimmer
    Try 2100 for the entry level 4-channel amp. Yan ang gamit ko ngayon budget meals muna... abang abang lang sa mga hidden "treasures". Di pa naman nag ooverheat sakin, wag lang isagad yung gains, mga nasa 1/2 lang.
    Dec 2003
    #30
    ah yes tama ang trick dyan di itaas ang gain..wais! hehe
    Mar 2004
    #31
    The problem with the fake v-12 is mabilis magkastatic. I also see a lot of the bigger (actual size) and less expensive (nasa 3100 lang) I tried one in my 15" kickers and medyo ok naman yung sound nya kaya lang ang bilis umunit. for starters ok na siguro but personally I'd really invest in a good ampli than subs. Even if you're using targa subs with a a good amp that will sound better than using kicker subs and a cheap ampli.
    Mar 2005
    #32
    totoo yun.. ampli ang pag gastosan mo papi..
    Apr 2004
    #33
    ako rin gusto ko mag-paayos... baurtwell, hindi ko na kunin yun retractable DVD player ng alpine, 70k! kung sa pinsan ko 35k pero ayaw niya trade-in...
    alpine CDA-9833 unit ko, front speakers and rear STOCK lang ng honda... ano magandang unahin? dls speakers? or v12 amp?
  14. #34
    van_wilder: Depends on your preference, but my suggestion is to get a good pair of seps and an amplifier (4 channel), the sub and rear fill can follow later (handa na lang muna yung wiring). BTW is that a Honda Civic? If so, try inquiring for 5" seps, if your going for 6.5" seps, you might need to do some modification on your door panels. HTH.
    May 2005
    #35
    ano ba ung seps? ako din honda civic....i heard sumthng about bafle???? tama ba spelling? ano ba un? sensya na mga pre mejo wla pa tlga ako alam sa kotse...super newbie
    Apr 2005
    #36
    Quote Originally Posted by radiskull0415
    seperates = speakers for vocals
    buffles= box for the speaker (can be seperates or subwoofer)
    Mar 2005
    #37
    Quote Originally Posted by van_wilder
    waahhhh.. ang mahal nga nung alpine. ayaw mo ba ng 35k na may LCD monitor and JVC dvd player with tv tuner...
    May 2004
    #38
    sir sa raon ka bumili ng mga gamit mo, then get a good installer bayaran mo ng labor
    option 2 is to buy a good second hand set of speakers or sub/box and pa install mo sa kilala mong installer
    sa ferosa ko 12000 lang nagastos ko all in lahat second hand pati abc box, mp3, seps , v12
    Mar 2005
    #39
    try mo din maghanap ng 2nd hand items na in good condition...
Pano ko setup sounds ko?
