Results 1 to 7 of 7
- May 2011
- 26
February 27th, 2012 10:31 AM #1Sabi nila palagyan ko daw filter sa stereo ng kotse ko na pioneer.sabi naman ng iba lagyan daw tweeter ng capacitor o condenser yata pero may ganun na nakalagay.sabi pa ng iba baka yun tweeter na may diperensya o baka shorted daw amplifier ko dahil dun din nakakabit tweeter ko.V12 po ampli ko,3600 watts.
Tinanggal ko muna tweeter ko at wala na nag iispark pag nagbubusina at preno ako.pero mas gusto ko pa din may tweeter kasi masmaganda tunog.Ano po sa tingin nyo bat nag iispark tweeter pag nagbubusina at preno ako?
February 29th, 2012 10:14 AM #2
It is another term of electrical faults na always available sa car audio system lalo na V-12 ang amp mo, it is a high pitch signal na sa tweeter mo lang maririnig, sometimes, sign ng clipping signal ng amp, maaaring mataas ang gain, or bad grounding, maaari din na nakadikit yung signal cable mo sa power wires mo, beter inspect each one. One thing, naririnig mo lang ba yung parang spark na sound sa tweeter mo kapag naka start ang makina?
February 29th, 2012 07:42 PM #4
Tingin ko bad grounding. Try to trace the wiring baka may nagsalubong na positive and negative. Stock ba busina?
- May 2011
- 26
March 4th, 2012 10:54 PM #5
- May 2011
- 26
March 4th, 2012 10:57 PM #6
March 8th, 2012 09:10 AM #7
pa check po ng amp, baka mataas ang gain, or yung power supply nyo po is below to the recommended wire gauge (at least gauge 8), pwede rin po na magkasama yung power supply nyo sa signal cable like RCA wire and speaker wire kaya nasasagap nung tweeter yung feedback ng relay ng busina nyo, pag bad grounding naman, baka masyado mahaba yung ground wire nyo kaya may static...
Xiaomi E-Car
