Results 1 to 10 of 11
November 7th, 2007 04:14 AM #1
is there such a thing as original car fuse (those colored fuses)? it's more expensive than those common cheap ones but less prone to melting?
November 8th, 2007 02:55 AM #2
yep yan ang tawag nila sa autosupply shop pag sinabi mong orig yung mas high quality ibibigay sayo
November 8th, 2007 04:22 AM #3
OEM fuses or the surplus one OK compare mo yung 2 feet ng fuse mapapansin mo na mas makapal yung mga surplus
November 8th, 2007 10:10 AM #4
Fuses are designed to trip at a certain amp. If they trip at a lower amp, the quality might be suspect.
But if they trip at a higher amp, it doesn't mean they are of better quality. Remember, fuses are designed to be weak links. They destroy themselves to save more expensive components. If you keep blowing fuses up, it might be time to have that particular area in your electrical system checked out.
Tsikot Member Rank 4
- Jun 2006
- 2,605
November 9th, 2007 05:36 AM #6
indeed. but with a prescibed amp. fuse that will just melt the plastic, yet the link doesn't break?
November 9th, 2007 12:03 PM #7
think one of the possible reason is a loose connection or weak plastic that cant stand the heat!
just encoutered this when i switch to higher watts ng headlamp,the fuse just keep on melting! then got an idea to change the socket type to a glass type and now still working without worries
November 11th, 2007 01:47 AM #8
thanks, that's a good idea. but I believe the fuse holder should be those plug attached by screws. because I had use one before, those fuse holder wrapped in plastic casing... they still melt...
January 9th, 2017 09:40 PM #9
i busted a darn fuse today. saan a nakakabili ng mga oem fuse. sa suki ko wala eh. although i remember nakabili ako dati ng surplus na fuse from another shop. puntahan ko nga bukas. sinagot ko tuloy sarili kong tanong
- Nov 2016
- 13
