Results 1 to 4 of 4
- Dec 2008
- 11
December 14th, 2008 02:13 PM #1Guys pls feel free to post your opinion on this product just want to know the pro's and con's of it thanks!!!
December 14th, 2008 10:50 PM #2
MangBoy let me be the first to give you my opinion, I have exactly the same setup except mine is Lrx5.1..first of all MLK165 is known for its SQ qualities and the only seps that has passive time alignment called HFC (high frequency contour) you can select listening sweet spot in center of the passenger and driver seat, or driver seat and passenger seat.. all you need is set the HFC switch on the passive cross over. Also Bi-amplification option that can give more control on tuning.. on full active its even sounds great but using Lrx3.1 you cant do full active with it.
The ML2500 2008 EISA winner for best subwoofer.. placed in a sealed box can give you clean and accurate low base notes.. the only V cone shaped sub woofer.
Lrx 3.1 the perfect 3 channel amp to MLK165 and ML2500, I believe this amp is made for this combination..
Lastly I won EMMA 2008 SQ regional compitition on these setup..
- Dec 2008
- 8
December 29th, 2008 06:19 PM #3let me know about this product.
if it is possible then also send me photos of this.
- Dec 2008
- 8
December 29th, 2008 06:24 PM #4let me know about this product.
Ask ko lang naka by pass na ba Yan or servo pa din ang gamet mo
4g15 rare Idle motor (servo)
