wat kind of amp pwede sa PG 15 inch sagad na power, na below 4,000 pwera v12?
thanx
thanx
Try mo Fenton. Some of the other cheaper amps I saw is Boschmann 75W x4 channels (which I own one at 3.5k) and Proline 350W x 4 channels (2.5k).You may also consider nd hand units that may fit your budget.
alam ko mas ok pa v12 kesa boschman.. mejo sablay ata un brand na un
My Boschmann amp is already 6 months old and still going. I use it only to power the door speakers. My tubular sub has a built-in amp. I suggest you buy amp with higher output just to be sure. The cheapest recommended amp brands that most audio buff suggest is the V12 and Fenton.Originally posted by notEworthy27
roydok, ok ba yung boschmann??![]()
Buy 2nd hand if on a budget.Wala namang moving parts ang amp para masira. Just give it a check kung hindi nasunog ang internals.
