Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
    Oct 2004
    #41
    Originally posted by 27th_Faktory
    i have a budget of 13k for buying a set of separates, which do you think i should by based on your experience.
    I suggest you buy the JBL 6x9 competition series. It really sound great. I think it costs less than 8thou a pair at a power rating of 250 Watts RMS. Its the best stand-alone pair for the rear. For fronts, youll have a wide range of brands to choose from. Lanzar 2way coaxials cost less than 4thou a pair. Buy the 6 inch door mount type. Make sure you buy front speakers not less than 6 inches in diameter. Youll be amazed to hear the clear blend of sound produced from those speakers. For assistance, dial my contact no.
    Oct 2004
    #42
    sir benta ko yun akin 1k yun red na may fan pero may cra yun isang channel
    Reserve mo sakin yan.
    Feb 2004
    #43
    13 grand for separates? malaki na yan.
    punta ka sa kotseaudioclub.com ang daming magagandang slightly used doon na separates.
    andy
    Jan 2003
    #44
    hahaha i was thinking infinity dami kasi nag sabi ganda tumunog yun
    lucktruck
    magkano last price ng RF mo sold na ba yun, balak ko kasi yun RF na lang kunin para RF amp all the way. pa pm naman sa KAC.
    carlo_27th yun handle ko
    Aquaman
    sir nag mamadali po ako i dispose yun whole set up ko kasi mag papalit na me para isang pagawaan na lang. wlala ng balikan
    Oct 2004
    #45
    lucktruck
    Aquaman
    Ok lang, sir kung nagmamadali ka. Ok lang.
    Feb 2004
    #46
    kunin mo na lang lahat ng gamit ko tapos sell the others except the Punch 200? okay din yung epicenter kung gusto mo parusahan ang subs mo.
    andy
    Apr 2005
    #47
    Quote Originally Posted by Supierreman
    kung budget amp na rin mag Fenton ka na lang. Mas malinis daw to tumunog compared to V12 amps. Lifetime warranty pa. If you plan to power the rear get 4 channel amps. sabi Vic pena sa lecture nya dun sa transhow pag seps you a 50-150 watt amp is enough.
    sir...where can you buy fenton amps??
  8. #48
    Paul Vincent Electronics in Raon
    Apr 2005
    #49
    Quote Originally Posted by ILuvDetailing
    thanks! thanks!
    i think i'll go for the JBL gto 506c 55w RMS - 165w...as a starter 5k lang muna budget ko...i'll what happens sana ok tumunog...hehe...
    or i'll go to megamall first next weekend sa transhow...
    Apr 2005
    #50
    mga sir question lang po...
    bakit po sa sounddomain website ang mahal ng jbl gto506c? nasa 180 bucks sya?
    eto po yung link:
    http://www.sounddomain.com/item/JBLGTO506C
    yung napagtanungan kong store less 5k lang...hmmm....then isa lang crossover nsa box??? di ko nakita kung may isa pang crossover... di ko kasi nilabas lahat na nasa box....
    any comment po jbl users? curiuos lang po....
    #51
    *carlo, add ka 1k naka type x ka na!
    Apr 2005
    #52
    Set UP: All stock (except audio) 98 Corolla XE, midnight blue.
    Pioneer HU
    Blaupunkt IC 165 XL seps in front (6.5", 120 Watts max each, I forget RMS, 80 ata)
    Same seps on the rear
    2 Blaupunkt TSw 300 subs (12", 600 Watts max each, sealed box)
    Blue neon lights located at the rear of the subs inside the box.
    V12 NV805 amp for seps (4 CH, 2000 Watts max daw)
    V12 MRVF-450S for subs (4 CH, 3000 Watts max daw), 2 Ch lang ginamit, di pa ata brinidge
    ISSUES: SEPS RELATED
    1.)I know V12's max power is overstated so I don't know if the wattages (?)match.
    2.)IF, IF lang po, kasi ang mahal eh (10K), I change to Velocity seps, 350W max, do I need to change my seps amp? Nakalagay kse "500W X 4 Max Power Output" pero sa ilalim "150W/Channel RMS Continous Output * 0.5 THD (20Hz to 20KHz, both channels driven into 4ohms load)" Ano daw?
    3.)I think my subs are fine, I think my seps are too weak (gumagaralgal pag malakas), I don't know if volume is too strong, the amp is too strong, or the seps are weak. (I'm hoping it's not coz I'm going deaf).
    4.) Do I really need seps at the rear? I plan to sell all my seps, buy a better pair (mga 6.5K budget) and probably reinstall the stock rear speakers. OR do I need to realize that I'm lucky enough to have aset up in the 1st place and be contended with what I have and just have it tuned properly (if this is the case, saan ho? Fairview, QC ako)?
    5.) I am guilty of buying the setup all at once without studying the subject 1st. Now that I read the threads, I think (know) I made a LOT of mistakes. I just dunno were to begin.
    Any suggestion on how to MAXIMIZE this set up OR how to improve the setup with minimal added cost (naka 30K plus napo ako) will be GREATLY appreciated.
    Thank you
    Feb 2004
    #53
    my personal opinion, have your speakers checked by a professional, if they are still in good conditon, i think the first thing that you should do is change your amps. you will be amazed at the difference in clarity if you switch to high end amps, especially for your separates.
    andy
    Feb 2005
    #54
    Ako rin mukhang bitin ang amp mo para sa seps mo. Check nalang din the seps kung sumasabit na.
    Apr 2005
    #55
    Thanks for the toughts. I checked the amp.Ok naman wattage, 150w RMS. 80w RMS yung seps e. Mas malakas lang talaga ata ang gusto ko. Was gonna buy kicker seps kaya lang baka mabitin lang ulit (250W max daw). How much decent na 200-250w RMS sa seps? Yung Sony Explode (200w RMS ata)close to 9K na e. Yung Blaupunkt Velocity naman 350max, 10K. Any suggestions on a strong, clear seps (papalit na lang ako ng amp) na nasa 7K range?
    Re high end amps, high end din presyo. My plan is to set up a good speaker system and SAVE up for branded amp. Speaking of branded, do I beed to change brand? Blaupunkt kse lahat speakers ko. Am I paying for the brandname rather than for the quality itself? If yes, what "not-so flashy" but "high quality" brand can you suggest? Wanna pay for the speakers, not the name.
  16. #56
    DLS, JBL, Rockford Punch are good amps. Just pricey especially with the power requirement of your seps. Check out the DLS and JL seps, IMO its better the kicker seps.
[Merged] help: what separates i will buy
