Originally posted by doy Madaling uminit ang V12 MRV-F705, sir, especially if used with a sub. Pero ok lang siya kung seps ang gamit. Kung masyado nang mainit, magtemporary shutdown ang amp(protection mode). Just let it cool down for mga 15mins and lower the volume nalang. Mas madali siya mag-offset kung naka-parallel connection(2ohm load) ang seps/speakers sa amp. Not sure kung Korea or Taiwan ang "orig" sa fake Alpine. Ok naman siya for budget-meal.
Ok din ang V12 na amp. Kung low budget kayo, kunin nyo ung 2000 watts or 3200 watts. Both amps have built-in blowers. But i suggest na palitan ninyo ung blower nya ng ball bearing type kasi d tumatagal ang factory blowers nyan. Kapag nag-stall ang blower, sira ang amp pati subs nyo.
I modified a V12 3200/2000 watts amp. It uses Toshiba power transistors and i replaced it with STK type transistors and placed 2 ball bearing type blowers. I drive it then with 2 12" Kickers Freeair, 1 15" Kicker Comp VR, And 1 MATTS 15" subs simultaneously from 8am to 10pm. The amp did not even warm up. You can touch it with your palm.
Originally posted by extinction ok yan sir ah! ganun nga rin sinasaggest ng friend ko palitan daw yung blower pero ano pa kaya ang amps na medo mura na ok din for seps?
AR tnx sa info about my mb atleast ok din pala nakuha ko
peace
Kumuha ka sa raon ng V12 na Taiwan or Korea. May nakapagsabi na makukuha mo lang ng 1800. Merong 2000 watts nyan na blower type din. Just make sure to replace the factory blower with ball bearing type blowers. Kapag nagoverheat ang amp mo masisira ang power transistors and it will feed high voltage sa speakers mo. Masusunog ang speakers kapag nangyari yon. Mas maganda na may power ka kaysa wala. Mas maganda ang clarity mo kung may power ang gagamitin mo sa separates mo kc lesser ang distortion at labas ang instruments and vocals dahil hindi hirap ang amp mo. But i also suggest you use not less than 6 inches ang diameter ng seps mo and use a pair of 2 way coaxial cone speakers kaysa ung hiwalay na seps. mas mataba kc ang boses kapag mas malaki ang speakers mo. Hindi tunog ipis ang vocals- if you get what i mean. Sa rear naman 6x9 is still the best. kung sigurista ka, use speakers with ratings not less than 250 watts rms.
aquaman san mo nabili yung transistor mo at blower? naka v12 32000w amp din ako e. kaw ba nagpalit magisa non? binuksan mo yung amp mo? parang kakatakot kasi buksan yung amp baka mayari.
Originally posted by alpha-q aquaman san mo nabili yung transistor mo at blower? naka v12 32000w amp din ako e. kaw ba nagpalit magisa non? binuksan mo yung amp mo? parang kakatakot kasi buksan yung amp baka mayari.
Sir, kung buo naman ang V12 amp mo no need to upgrade the transistors. Kung sira naman, its better to upgrade. Ang transistors kc cost 250 to 300 pesos dito sa local area ko. At 2 pcs per channel it will cost you 2000 to 2400 pesos diba. Hindi practical. So to prevent this, klangan palitan yung factory blower nyan. Kunin mo yung size ng blower at maghanap ka ng blower na ball bearing type or atleast heavy duty. Then iparralel mo sya sa existing blower ng amp. Siguruhin mo lang ang polarity na hindi baligtad ang ikot ng blower. Kung d mo alam ang gagawin dalhin mo sakin ang amp mo.
sir aguaman tnx sige hahanap nga ako sa raon mag ccanvass na muna ako
pero mas mura kaya kung sa banawe na ako kukuha kasi libre kabit na??? hindi kasi ako marunong sa electronics eh =)
sabi naman nung iba yung v12 daw hindi naman daw gaanong umiinit kapag separates lang ang i-ppower nya? tama ba yun? medyo naguguluhan lang kasi ako hehehehe
atsaka kunin ko yung model ng v12 na ok pang separates yung hindi umiinit! kasi i-ppower ko sana sa separates ko (mb quart dsd 210) 4" lang at stock ko na pioneer 6x9 4way 180 or 200 watts ata yun
Originally posted by extinction sir aguaman tnx sige hahanap nga ako sa raon mag ccanvass na muna ako
maraming salamat po =)
Masyado kasing commercialized ang audio setup sa banawe. Pangit pati parts dyan. Mahal ang V12 sa banawe. Ano nga pala setup mo? May subs ka ba?
kung budget amp na rin mag Fenton ka na lang. Mas malinis daw to tumunog compared to V12 amps. Lifetime warranty pa. If you plan to power the rear get 4 channel amps. sabi Vic pena sa lecture nya dun sa transhow pag seps you a 50-150 watt amp is enough.
yup naka set up ako sir aqua kaso kailangan ko pa ng ampli for my separates na (mb quart dsd 210) kaya naghahanap ako ng magandang ampli na mura na maganda/ok
kukunin ko sana yung model ng v12 na hindi nag iinit
naka rear speakers na rin ako 6x9 pioneer na 4way yun yung sa itaas ng sandalan ng rear seat nakalagay
yung sub ko naman Lanzar Viberant na may built in ampli na! 600watts daw yun kasi nabili ko sa barkada ko yun, (na binili nya sa concorde) bale 12" yung sub 1pc. tapos nasa box na rin na may built in ampli
yan set up ko sir by the way galant gti body auto ko
so far ok naman yung soun kaso parang bitin lang sa harap kasi kailangan daw ng ampli for separates para mas maganda yung clarity, kaya tanong ko lang kung anong magandang model ng v12 na hindi gaanong umiinit or baka may alam kayong ibang brand and model ng ampli na ok sa set up ko
Originally posted by extinction yup naka set up ako sir aqua kaso kailangan ko pa ng ampli for my separates na (mb quart dsd 210) kaya naghahanap ako ng magandang ampli na mura na maganda/ok
salamat ng marami =)
Ok na yang setup mo, sir! kumuha ka nalang ng 4way na amp. Try mo yung V12 na MRV-F705 model. Kung seps lang ang iddrive, ok na yan. Mura mo lang mabibili yan at may built-in crossover pa kaya madali magtono nyan. Tumingin ka sa raon kc mas mura dun. Dun lang kinukuha ng mga audio setup shops ang mga amp. Kung may makukuha ka naman na JBL na GTO model kahit second hand puede na yun. Malinis tumunog yon. Kung makukuha mo V12 na 705 model, amplify mo na rin yung 6x9 mo. Kung gusto mo kontakin mo ko ako magtotono nyan.
About the MRV -F705 heating up and shutting down, I've never had an experience like that.
My 2 MRV - F705 (1000watts daw) is powering 2 subs rated 300 watts RMS per sub, including stock fronts and stock 6x9's so far ok pa naman.
I usually drive the subs very hard listening to bass/ or hip hop tracks. In short, I'm saying they're OK. Although if I had the money I would've gone for branded amps.
