Results 1 to 4 of 4
    hello po... bago po ako dito... ask ko lang po kung pano mag match ng sub at ampli especially po sa wattage nito.. kasi po meron po nag advise sa kin dapat daw mag ka pareho ng rms ng sub at ampli... tama po ba yon....?
    Mas maganda mas mataas wattage ng Power amflifier kaysa sa Power handling capacity ng subwoofer para busog na busog ito at maganda ang bayo. Kung mas mataas subwoofer kaysa sa Power amplifier mapapatunog kaso madaling mag init at hirap ang Power amplifier.
    Quote Originally Posted by speed unlimited View Post
    +1 as above pero yong nagsabi sa iyo(thread starter) ay may possibility na tama din siya dahil hindi po lahat na subs or manufacturers recommend overpowering there subs. But then again Overpowering you can avoid this (kahit twice pa ang power ng amps mo sa sub) by adjusting properly the Head unit's volume and the amps gain...
    And IMO I would look for a sub na higher ang sensitivity.. and especially may mga subs na ngayon na lumalabas may purpose na po..eg. Good for SQ sub, good for SPL or both.. Then if your into streetbass(low notes bass) try to look for Lower Fs value(feature of the sub) the lower, the sub will perform well on low notes..
    just my 2cents
    under power or over power man ang sub as long as well level matched ok lang yan.. hindi masisira ang mga gamit mo.. Just make sure to have it installed with a reputable shop. Mas maganda if over ang ratings ng amp but it depends sa gamit. May mga amps na under rated lang so as subs. Just whatever equipment you choose make sure to level match properly para kahit sagad volume hindi masira. you could also join kotseaudioclub.com for audio enthusiasts forum
match of sub and aplifier
