Quote Originally Posted by speed unlimited View Post
Mas maganda mas mataas wattage ng Power amflifier kaysa sa Power handling capacity ng subwoofer para busog na busog ito at maganda ang bayo. Kung mas mataas subwoofer kaysa sa Power amplifier mapapatunog kaso madaling mag init at hirap ang Power amplifier.
+1 as above pero yong nagsabi sa iyo(thread starter) ay may possibility na tama din siya dahil hindi po lahat na subs or manufacturers recommend overpowering there subs. But then again Overpowering you can avoid this (kahit twice pa ang power ng amps mo sa sub) by adjusting properly the Head unit's volume and the amps gain...
And IMO I would look for a sub na higher ang sensitivity.. and especially may mga subs na ngayon na lumalabas may purpose na po..eg. Good for SQ sub, good for SPL or both.. Then if your into streetbass(low notes bass) try to look for Lower Fs value(feature of the sub) the lower, the sub will perform well on low notes..
just my 2cents
