Results 1 to 10 of 43
- May 2006
- 12
June 1st, 2006 01:25 PM #1mga bossing tanong lang.ano b babagay sa head unit ko?i have a alpine CDA-9854L.i dont have any idea pano mag setup.ung babagay na rin sa corolla xl.tnx
Tsikot Member Rank 3
- Dec 2002
- 551
June 1st, 2006 01:54 PM #2how much is your budget ? There are a lot of potential for your corolla. But it really depends on how much you want to spend
- May 2006
- 12
- Feb 2006
- 14
June 2nd, 2006 10:14 PM #4mag tanong ka sa mga installer na kunwari ganito ang set up mo.dalawang tweeter,apat na 6x9 isang subwoofer at isang power amplifier. siguro namn may mas murang set up na ganyan at oras na napakingan mo ang set up na ito lahat nang tao ay lilingon.mag add ka tuloy nang capacitor na 15 volts 120,000 microfarad na polarized lang para positive nang capacitor ,positive din sa baterry at negative nang capcitor ay negative din nang baterry.itong capcitor ay para hindi madaling mag discharge ang baterry mo.
June 2nd, 2006 10:20 PM #5
30K sobra na tol yan!
headunit - 9-12k
seps & rears - 8k
subs + amps - 10k
others - yung sobra
June 2nd, 2006 10:22 PM #6Originally Posted by ortitzrl
di na kailangan capacitor kung isang sub lang bro....
June 3rd, 2006 08:55 AM #7
di na siguro uso mag set-up ng 6x9 sa ngayon. for 30K you can get a good quality seperates for the front 6.5", one 10" sub kicker na comp ok na and one 4 ch amp. you dont need rear fills na.
- Jun 2006
- 19
June 3rd, 2006 05:59 PM #9tanong lang po mga tsikoteers, ano po ba advise nyo na affordable amplifier? saan at magkano po kaya?
- Jun 2006
- 19
June 3rd, 2006 06:04 PM #10hindi pa po kasi ako familiar kung paano tumingin ng original ampli. ano po ba ang rms at pmpo? usually po kasi pmpo ang nakikita ko available sa market. thanks in advance
Ride Safely!
high idle RPM at engine start
