Results 1 to 5 of 5
- 44
June 7th, 2004 04:27 PM #1mates,
i wanted to connect my alpine 6disc cd changer from my old car to my new car. problema ko, kenwood yung HU ko. pag-check ko dun sa pins, hinde sila match. may nabibili kaya na parang adaptor para naman maikabit ko sila?
thanks.
June 7th, 2004 04:32 PM #2
bro, i'll rename your thread to make it easier for others to give some inputs.
BTTT:
AFAIK, you cant connect an HU and changer of different brands unless you make use of a universal cd changer which is FM modulated. it will utilize a slot from one of you FM station presets. problem is, your audio cd will be limited to that of radio quality only.Last edited by ssaloon; June 7th, 2004 at 04:35 PM.
June 7th, 2004 04:58 PM #3
Also, if your Alpine CD changer is "Ai-Net" (model number usually has an A, e.g. CHA-nnn) your HU needs to be Ai-Net capable and usually Alpine ang meron nito.
For CHM-nnn models, baka may non-Alpine HU na compatible but I haven't had any experience with them.
- 44
June 8th, 2004 09:53 AM #4mates,
salamat sa inputs. kung ganun pala, i'll have to sell my CD changer na lang. any idea how much?
high idle RPM at engine start
