Results 1 to 5 of 5
August 19th, 2017 07:14 PM #1
Good day Tsikoteers,
The disc tray on my Kenwood 10 disc changer wont's eject. I can only hear the clicking sound when the eject button is pressed. I can't find any button that can manually eject the tray.
BTW it is installed in a Honda Cr-V 2000.
TIA
- 52,731
August 20th, 2017 09:31 AM #2my experience with (my non-kenwood) disc changer.
a slot container has not one, but two discs in it.
i had to dismantle a bit the thing, to manually get them out.
it worked fine, after that.
how two discs got into it, i do not know.
i know.
disc changer is so... ancient!
but so am i.
August 20th, 2017 02:54 PM #3
Normally, theres a pin hole where you can insert a pin in order to manually eject the disc
Turn off the HU then insert a straightened paper clip into that pin hole
If you cant locate the pin hole, then you just have to pry open the HU itself
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; August 20th, 2017 at 02:57 PM.
September 14th, 2018 05:20 PM #4
- 52,731
September 15th, 2018 10:45 AM #5my wild guess is, you have 2 cds in a space designed for only one.
the unit will have to be manually pried open, in my opinion.
good luck.
high idle RPM at engine start
