Results 1 to 8 of 8
- Nov 2006
- 122
February 1st, 2007 05:22 PM #1Mga sir my solution pa ba sa kalansing ng trunk due to sub punch.Medyo SQL kasi set up ko annoying tlga ung tunog sa trunk pag sa labas ka pero sa loob no problem panalo sa tunog.ae101 lang po ride ko.thanks sa mga magrereply.
February 1st, 2007 06:37 PM #2
solution one: lower the volume of your audio system.
solution two: tighten all loose bolts & screws. Add padding or foam to panels to avoid rattling.
- Nov 2006
- 122
February 2nd, 2007 01:52 PM #4
dynamat is your friend.
also the biggest culprit of sub rattle is your license plate. make sure it is tightly secured with 4 screws and get rid of your plate frame if you have one.
- Nov 2006
- 122
February 2nd, 2007 05:20 PM #5M54- San nkakabili ng dynamat,meron ba nun sa blade or ace? Pano application nun? Thanks
February 2nd, 2007 06:54 PM #6
If you are on a budget, Flashband ang gamit nilang Dynamat substitute sa Kotseaudioclub. It is not an audio product. Ginagamit siya for house construction. You can buy it rolls sa ACE.
February 2nd, 2007 07:17 PM #7
ganyan din naging prob sa old car ko.. since the subs are facing the big door sa likod (99rav4) yun plate and the plastic cladding sa labas nagrarattle pag mejo napapalakas yun sounds... my cuzn gave me parang rubber-ish strips na mejo makapal... we removed the plate number nilagyan namin sa likod ng rubber strip and we actually removed na the glass cover of the plate since kung lalagyan ng rubber strip masagwa... my uncle did the body cladding na plastic using the same rubber strips nilagyan nya lang yun parts that comes into contact with the body of the car... the strips BTW has an adhesive side so walang prob sa pagdikit...
like what sir m54 said take out na lang your plate frame if you have one.
and also putting yun rubber strips sa plastic body cladding nun car helped a bit but then the rest na theres like a space between the metal body of the car and the plastic cladding still makes some weird vibrating sound when the music is up and the door is closed... hope it helped a bit.
February 6th, 2007 06:02 PM #8
eto ba yun doc?
http://www.diytools.co.uk/product.as...20!TB_EVOFB300
eto yung dynamat, mahal pala...
http://www.dynamat.com/products_car_...trunk_kit.htmlLast edited by ownertype; February 6th, 2007 at 06:05 PM.
mikel arteta coat 2023 williamjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
