Results 1 to 7 of 7
- Sep 2003
- 4
September 25th, 2003 12:05 PM #1Peeps!
I am planning to get a 2nd hand of this sub. I have a 1 cu ft sealed box and a V12 MRV705 amp. Fit ba siya dito?
Thanks!:worried:
September 25th, 2003 01:47 PM #2
Will probably work but will not sound that good..box is too small.. the 12w6 will work best at 1.5-1.75 cu ft box...
also if you plan to get a single 12w6, make sure your amp will be able to handle a dual 6ohm sub... sayang lang amp if you wire the sub in series
- Sep 2003
- 4
September 25th, 2003 03:43 PM #3Thanks Beefy
How will I compute for that ba? Here is the published specs of the amp - 85w x 4 * 4ohms, 250w x 2 * 2ohms
September 25th, 2003 09:54 PM #4Originally posted by galantvr6
Thanks Beefy
For a single 12w6
parallel wiring = 3ohms
series wiring = 12 ohms
check out this link
Wiring
September 26th, 2003 11:39 AM #5Originally posted by Beefy
Most amp. are 4-8 ohms stable, its better to get a mono amp (most 2 ohm stable) and wire it parallel (3 ohms).;)
- Sep 2003
- 4
September 26th, 2003 04:31 PM #7Originally posted by SiAKOL
According to my JL catalog the recomended sealed enclosure for 12W6 is 1.25 cu.ft. and 2.00 cu.ft. for ported.
Xiaomi E-Car
