How will I compute for that ba? Here is the published specs of the amp - 85w x 4 * 4ohms, 250w x 2 * 2ohms
R u sure 250 x 2 * 2ohms yan? Baka 250 x 2 * 4ohms.. I doubt kung kaya bumaba ng 2 ohms bridge yan.. only 4 channel amp that I've encountered that can go down to 2 ohms bridged (1 ohm stereo) is soundstream
For a single 12w6
parallel wiring = 3ohms
series wiring = 12 ohms
Originally posted by SiAKOL According to my JL catalog the recomended sealed enclosure for 12W6 is 1.25 cu.ft. and 2.00 cu.ft. for ported.
Most amp. are 4-8 ohms stable, its better to get a mono amp (most 2 ohm stable) and wire it parallel (3 ohms).;)
The recommended spec by the manufacturer is not always the best... I've heard a w6 play better in larger sealed enclosures... the bigger the better... but up to 3.71cu ft only for sealed to get a qtc of .707
