Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 80
    #21
    malugay street i think it was... not too sure anymore... it's behind this public school i believe
    #22
    medyo may kamahalan sa maxx-energie ventures corp...nagtanong lang ako ng 3.5 jack to rca nasa 150 petot isa sa kanila...nakakita ako sa concorde sa mega nasa 50 petot lang ang isa...bili ako tatlo, ngayon pwede ko pa gamitin ipod ko sa 2 component ko sa bahay he he...yung natitirang isa para sa kotse kaso kailangan ko pa ng PIE at isa pang cable...
    try nyo muna magtanong sa mga access shops...
    #23
    Karplus
    7274 Malugay
    Makati City
    Tel. 816-0828, 841-0470
    chieffy,
    yung mga jack to RCA kahit sa labas na bilhin yun. Ang ok sa maxx energie yung Aux in cable lang nila :D
    Yung kenwood is around 1.8k hirap maghanap nun usually sa US pa makakabili. Yung pang pioneer nila mahal nga lang at 2.2k eh yung orig Pioneer CDRB10 less than 2k lang.
    Jan 2003
    #24
    what about this one? is this available locally? Kenwood KCA-iP500. its supposed to control your ipod through the head unit.
    Jun 2005
    #25
    paano kung walang aux-in, cd-changer input, at casette player ang HU ko?
    FM transmitter na lang ba only way para ma-connect ko iPod or other similar devices?
    #26
    Quote Originally Posted by Engr
    any car stereo can be hacked to have aux-in ... it is easy if you have a schematic diagram ... without schematics, you'll need an electronics wizard
    Jun 2005
    #27
    Quote Originally Posted by kinyo
    'pre,
    may kakilala ka or alam na shop? Kenwood KDC-1012 itong HU ko, stock ng Adventure. thanks.
    Jan 2003
    #28
    bro just use the aux cable for kenwood. yung kabitan ng cd changer.
    #29
    engr ... sorry wala akong alam na shop na gumagawa nyan, pero sigurado ako marami dyan kayang-kaya nilang gawin
    diy lang ako sa electronics ... nagawa ko sa clarion stock stereo sa honda city namin, nakuha ko sa net yung datasheet ng power amp nya kaya madali ko nagawa ... if you simply tap at the input of the amp, you are basically mixing the signals from HU and ipod, so to listen from ipod alone, HU's volume must be set to zero and ipod's signal will take over ... but one must be careful doing the tap because it might need some additional resistors for level matching ... parts cost is no greater than P100
    good luck!
    Jun 2005
    #30
    may amplifier din ako na naka connect sa HU. pwede ba i disconnect ko na lang siya sa HU, tapos yung iPod ang ikabit ko?
    Feb 2003
    #31
    Jun 2005
    #32
    pwede ba yung setup na naka connect directly yung ipod sa amp and not through the HU? may negative effects ba ito sa amp?
    Feb 2003
    #33
    Jun 2005
    #34
    pwede ka ring mag change nang HU na kenwood (kdc-mp528). it already includes 2 pre outs and aux input. ipod ready, sirius and mp3/wma playback. ehehehhe
    Jan 2003
    #35
    with the ipod shuffle is it ok to just plug it in to an aux in (with a converter or the earphone plug to RCA sockets) of the HU or probably via a DIY aux in for the HU?
    #36
    yung mga OEM nang honda pwede kaya yun.
    may output kaya sila
    Apr 2004
    #37
    clavell,
    i think it depends on the honda model. i did research for my EK pero olats. Fujitsu Ten OEM nya and it does not have any aux lines. so for now, until i get enough dough to upgrade my HU, im stuck using cassette adaptors.
    #38
    Additional question mga kapatid.
    yung factory HU, may aux jack na parang pang headphone sa harap. may connector bang aux-to-aux to connect the iPod? So parang ang mangyayari, headphone jack to headphone jack ang connection. Amf, parang it doesnt make sense. Oh well, boplax ako sa stereo stuff..hehehe.
    TIA mga kapatid.
    #39
    ops, nevermind. I found it! "connection lead" pala ang tawag ng mga German. Its being marketed for 1 and 3 series.
    CONNECTION LEAD found on eBay
    :car:
    Oct 2005
    #40
    hello mga tsong,
    need some help sana on how to get my Ipod mini work on my DEH 4750 Pioneer HU. Bumili ako nung CD-RB10 na connector sa Jet Circuit nung Sunday sa may Malugay...It was installed by their technician pero nde namin na try kung gumagana coz that time nde ko nadala yung ipod ko...wala rin sila ipod so sabi ko try ko pagdating sa bahay dun ko na lang ita-try...pero nung sinubukan ko, Aux is ON tapos pag play ko ng music from my Ipod, sobrang hina nung naririnig ko..ni-try ko adjust yung volume ng HU pero naka 45 na sya pero mahina pa rin...
    Wat do you think could be wrong? Im planning to get back to Jet Circuit nect week para pa-check sa knila pero bk may solution kayo sa problema na ito.
    Thanks in advance!
IPOD Wiring/Integrate into HU
