Originally Posted by
arj
question lang mga pafs,
can i use 2 ohms on bridged mode? sabi kasi ng installer ko di daw pwede unless naka class d monoblock ako na amp. kung hindi, uusok daw ang amp ko haha! (nay!)
pero i believe his theory is flawed. AFAIK, you need a monoblock amp if you want to run on 1 ohm right? so, if my amp has a minimum speaker impedance of 2 ohms diba dapat running on 2 ohms shouldn't be a problem???
or, can i only run 2 ohms on stereo mode & not on mono . i have a dual coil sub 2 or 8 ohms (but currently at 4 ohms using single coil) & im thinking of connecting both coils at parallel mode to get 2 ohms...
now, my question is can i run a 2 ohm sub (coils rigged at parallel) on bridged mode (mono)? or do 2 ohms work only on stereo? pag naka 2 ohms ba ako di ko pwede i-bridge?
medyo duda kasi ako sa sabi nung installer na di daw pwede i-2 ohms yun sub ko at goodbye daw ang amp ko... ano ba ang tama mga papi???
TIA!
