Results 1 to 10 of 12
September 11th, 2015 05:55 PM #1
Such as this:
or this:
[img]http://ecx.images-amazon.com/images/I/41tm***Ap9L.jpg[/img]
Please point me in the right direction.
Thanks!
- Jul 2013
- 2,450
September 11th, 2015 11:26 PM #4
*oj
are you having noise?
*oj
September 12th, 2015 12:09 AM #5
Yeah, from the sub preouts to the powered sub. Vehicle noises, like computer buzzing, a bit of whining and pops when electrical loads in the car are turned on or off. Noises stop whenever I disconnect the preouts from the amp, so it's not the amp. No noises as well from the main speakers.
Checked all grounds and they're fine. I did found out that the amp RCA inputs have floating ground but not on the HU, so on the HU, the chassis ground and the preout/signal ground are common. So i've reason to beleive that there exists a ground loop.
September 12th, 2015 04:09 PM #6
aside from poor grounding system, check your RCA cables. never run/route your RCA along with any power cables. say if you have the RCAs laying on the left side of your car, run your power cable on the right then.
also check for stripped RCA insulators or there could be jammed/pinned RCA cable somewhere.
- Nov 2009
- 3,509
September 12th, 2015 05:43 PM #7Problem may be solved by wiring another ground line direct from battery, hu power supply, shielded cables up to the last audio accessory. This works for me everytime i encounter noise.
September 12th, 2015 06:08 PM #8
-how did you check the grounding? you can use a dvm(with fresh 9v batter) and all ground points should be 0.2 ohm
-the computer buzz/hum is the sound of coil whine in some motherboards or power supplies or videocards.
September 12th, 2015 07:11 PM #9
Or in my case, power supply or the vehicle ECM/ECU/PCM computer whine.
I really don't want to tear down the cables again and/or spend a fortune on expensive cables and grounding kits. I did mention that this just happens on the sub-woofer. I think that a ground loop isolator, even though it might just be a band-aid solution, should be enough. This, again is just covering the sub-frequency band, inserting a filter shouldn't cause it to lose perceptible sonic performance.
- Jan 2008
- 4,726
September 13th, 2015 10:45 AM #10Lipat mo yung ground ng sub amp mo. Use short cable. Loose grounding lang yan
