Results 1 to 8 of 8
February 26th, 2008 10:59 AM #1
i use a fm modulator for my ipod.
yung sa cdr king.
when i hit the gas, sa speakers meh tunog na hiss, na lumalakas tuwing i press the gas. this only happens when using the modulator. how do i solve this?
also,
car is is a city idsi, does the stock radio have a AUX in sa back?
or wala? para mag buy na lang ako nung adapter.
how much does the adapter cost?
February 26th, 2008 11:10 AM #2
hmmm...try to tune the modulator to 87.7 and manually scan using your HU. When I say manual you don't rely on the scan mode of your radio. Might be just off tune by a few khz.
February 26th, 2008 11:22 AM #3
i've read an article about this before and it stated that this usually happens when you plug in an amplifier or any dependent device in your HU that doesn't have any volume controls or something like that...i had the same experience with a low quality amp...nothing solved it so i had to replace the amp...so definitely the hissing sound is because of that modulator...i hope this helps
February 26th, 2008 12:16 PM #4
thanks, i guess last solution is buying a new head unit, w/ an aux in. usb simply won't work, ipod won't work on usb.ordinary mp3 pwede. ipod kc, technical masyado.
- Feb 2008
- 12
February 28th, 2008 02:58 AM #5madali lang yan, yung akin d naka dikit yung ground wire ko kaya everytime pag accelerate ko may madidinig akong hiss subwoofer ko.. dikit mo yung ground ng stereo or amplifier mo tsaka maglagay ka ng noise supressor para pag acc mo wala kang madinig na hiss sa speakers mo..
February 28th, 2008 12:03 PM #6
February 29th, 2008 04:55 PM #7
everything is fine kapag cd lang, or fm.
problem only happens w/ the fm modulator.
la na ata pag asa yung mga modulator na 1k below.
mga cdr king.
d ganon kaganda quality ng sound.
headunit na lang pagasa.
- Feb 2008
- 12
February 29th, 2008 06:34 PM #8
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
