Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Dec 2010
    pwd po pa help kung bakt ung subwoofer ko baliktad ung palo nya? dba palabas? xa papasok? ano kya prob nito??
    bawal SMS/TXT format
    Dec 2010
    Quote Originally Posted by ralphyboy11 View Post
    oooops sorry..
    pwde po pa help kung bakit yung subwoofer ko baliktad yung palo nya? dba palabas ung palo ng woofer, sakin papasok? ano kaya prob nito??
    Apr 2010
    oooops sorry..
    have you checked if the 'positive' and 'negative' wires connected to the speaker is correct? baka baligtad po.
    check mo yung connections. baliktad ang pagkakabit nyan.
    Dec 2010
    ok 2 isang araw eh, bigla lng nag kaganito ewan ko napano to..humina na ung bass nya eh..
    Baka nagkaroon na ng defect voice coil ng subwoofer mo.
    check mo yung phase sa cross-over kung meron.
    Dec 2010
    sabi kasi ng installer ko yung switch daw ng amp ung may prob, ewan ko pa kung sure na yun, kc hinihintay ka pa yung inorder ko na amp, para isa nlng trabaho, yung switch na sinasabi ko ay yung switch ng channels, para makapili ka kung 2 3 4 channels gagamitin mo,kaya raw minsan humihina minsan lumalakas..
    Dec 2010
    Jan 2011
    its better to try a new installer.. baka kasi pinapaikot ka lang niya para pababalik balik ka...
    and one thing
    [SIZE=4]please dont used text speaks[/SIZE]
    Dec 2010
    Quote Originally Posted by sk8_dem0n View Post
    and one thing
    oooops again. sorry.. try ko nalang rin pacheck sakanya, hindi pa rin naman nacheck up eh, tingin ko rin sa amplifier ko kasi mismo yung RCA nya hindi tumutunog yung isa.. pero thanks sa mga nagreply.. ayos talaga dito, marami nakakatulong..
    Quote Originally Posted by Ginnova View Post
    agree, maaring na-out of phased kung meron ka ngang cross-over/phase switch at posibleng nagalaw mo sya.
    imposible naman na nagkabaligtad ng connection yung installer mo, unless designed yung box mo para sa out of phasing connection drivers(speakers)
    popularly known as Isobaric speakers
    Dec 2010
    Quote Originally Posted by benchman View Post
    nakabit ko na ung bagong amplifier ko, pero ganun parin baliktad parin yung palo eh. hehe and wala akong crossover mga sir, 2 amps gamit ko, isang mono sa 15" sub HX2 and isang amp sa mid..
    kahit built-in cross-over wala? pano nyo nagawang low frequency yung papasok sa sub mo? same with the mid & highs?
    Dec 2010
    i mean yung crossover na sep, sa amp my crossover.. yun ba yung meron atang sira or something? yung bagong amp na nag dadrive ng subwoofer ko, pero baliktad parin ang palo, pero malakas naman, hindi ko alam bat baliktad palo nitong rockford hx2 ko..
    yun na nga, yung built-in cross-over mo sa amp...
    bagong amp para sa sub? means nagpalit ka na ng bagong amp pero ganon pa rin?(out of phased)
    hmmm... "baka" naman yung sub mo na ang may problema
    and wait... pano mo nasigurong baligtad nga yung palo nya? sa normal phasing kasi ng subs; pag heavy/deep bass ang nag-play... dapat talaga palabas sa box ang throws ng sub woofer mo, papasok ba?
    aside sa cross-over settings at polarity ng speakers, wala na talagang pwedeng panggalingan ng out of phased speaker/s eh... ipa-check mo sa installer mo, sino ba installer mo ralph?
    Jan 2009
    What is the model of the amp? Most amps allows you phase changes in a form of a toggle switch or a trimmer to adjust phase from 0-180 degrees.
    Other phase-related problems:
    1. Check settings on the HU if phase can also be changed there
    2. Check audio signal polarity all around. Though unlikely, the installer may have reversed the line signal going to the sub amp
    3. Finally, check the speaker polarity... + to + and - to -.
    Dec 2010
    Mga sir,since subs t0pic dito eh puwede din ba ako magtan0ng? amp ko eh yung 4channel, bridge yung 3-4 kaya dun inilagay ang seps,n0w ask ko lang kung tama ba yung ginawa ng installer ko sa subs ko which is ganito, yung positive wire eh sa ch1 positive nya inilagay,and yung negative eh sa ch2 negative nya inilagay.para kasing may kakaibang sounds akong napapakinggan eh. dapat ba eh sa isang channel lang ung + at -? example,connect ko sila both s ch1?
    Jul 2010
    Quote Originally Posted by dalandan27 View Post
    Sir di ba parang baliktad? kung and channel 3~4 mo ang naka-bridge dapat dun nakakabit and subs mo?
    Pero to answer you question yes kapag isa lang and subs mo pwede mo i-bridge ung channel 1~2 para mas malakas ung output na ibigay ng amp. So the positive wire connects to channel 1 and the negative wire connects to channel 2. The amplifier also has markings on where to connect the wire in bridge mode. HTH
help: subwoofer
