puwede rin po ba na sa headlight nalang po ako kumuha ng supply? since I only need a very small current from it.
yes, I will find a very good ground source.
if thats the case you'll be adding load to the original wiring of the headlite. lalabas naka direct tap yung load(87) pad nag trigger ang 30 sa diagram mo. bale wala na yung relay.
