Results 1 to 9 of 9
    Sep 2006
    hello peeps. pahingi po ng tulong. recently, we have a newly acquired car, syempre new ang battery. Now, i got an LCD and i want to play ps3 on it. So i bought this power inverter sa ACE builders, IFONIX 200 watts 220-240 volts daw.
    nung isaksak ko sya sa 12v via cigarette lighter plug, lumabas sa screen kaya lang maalon. So i though, wattage ang problema.. then i got this 600 watts naman na power inverter kapalit nung 200watts. Since mataas na ang wattage, ang supplied cable is the one with the clamps so direcho sa battery. I just tested it kanina, ayaw pa din, again, parang umaalon na tubig yung screen.
    Ano kaya ang ibig sabihin nito? hindi ba kaya ng inverter? eh mataas na wattage na yun ah. Kasi... nung isaksak ko yung PS3 sa 220volts AC via an extension in our garage, ayun gumana sya. malinaw at walang alon. With the inverters ayaw gumana ng maayos.
    Can anybody with knowledge in car electronics please help me? before i bring the inverter back for a refund
    thank you
    OT: question lang why would you want to play PS3 on your car? una maliit yun screen then it's uncomfortable, wouldn't it be more enjoyable to play it inside your bedroom?
    damn MTV pimp my ride...hehehe
    on topic: sorry wala akong alam dyan sa electicals....PSP ka na lang
    Sep 2006
    PS3 kasi madami din akong movies in mkv format sa loob ng hdd that can serve as video source. Actually di lang PS3 ang problema ko, pati yung HDD player ko may alon din.
    I've read somewhat na may kailangan daw i ground na cable (video cable ata)
    kaya lang di ako sure kung paano
    haaay
    Jan 2008
    that is noise caused by the inverter since you only have the same power source which is the battery...
    Mar 2005
    Probably just bad grounding or the engine's static affecting the PS3. Try running it with the engine off.
    Also some people have problems pag magkalapit yung power lines and rca cables. Try using cables with better sheilding.
    Will try to think about it some more HTH
    Mar 2005
    what do you mean sir everything in the car is powered by one battery
    i assume its on the grounding.
    its the same as getting statics inside the car.
    Jun 2007
    di kaya NTSC / PAL lang to? ung sa TV settings mo
    try mo din
    Mar 2005
    Quote Originally Posted by washburn View Post
    try mo din
    O nga naman high definition na kasi yung ps3 baka hindi kaya ng monitor
HELP: PS3 sa car
