Results 1 to 10 of 25
November 22nd, 2002 05:15 PM #1
guys need help.... have a couple of kapinteros at my house...and i need to build a box for my sub (Kicker 15in)....
wats the correct box size for this.... and wats the best material (wood) to use? tnx guys... :D
November 22nd, 2002 05:26 PM #2
what type of box would you want and what vehicle would you place it in?
- Nov 2002
- 50
November 22nd, 2002 06:05 PM #3Material to use: 3/4" MDF
Box size: Refer to the manual of your Kicker Sub.
HTH
November 23rd, 2002 03:34 AM #4
what is better for sq, sealed or ported? will place it in a corolla ae 101. the 3/4 is the thickness rt? sori kidd i dont have the manual na yata e :oops:
- 109
November 23rd, 2002 11:56 AM #6hmmm... for sq it's advisable you go sealed. some systems go ported but it would depend on the sub. Though IMHO sealed is the typical enclosure for SQ systems. Ported is typically for SPL systems. oh yeah, if ur going to use a 15" sub masasayangan ka. because in an sq system there is minimal play of the sub. people lessen the sub gain so that you can hear more of the kalansing ikanga ng mga tweeters and the mild thump of ur mid bass.
November 23rd, 2002 03:21 PM #7
for sq...sealed box is always preferred.
iagree with mon...ported is recommended more for spl because you can tune the box and the port to a specific frequency...blah blah blah....
- Nov 2002
- 50
November 24th, 2002 12:25 AM #8You're right, 3/4" is the thickness. Mond and Glenn are also right, that in most SQ systems, sealed enclosure is the preferred baffle design. Simply because it can play a broader range of frequencies as compared to ported and bandpass enclosures, and usually it has a "flat-er" frequency response than the latter two.
November 24th, 2002 04:03 PM #9
sealed it is... mond sori but thats the only sub i hav (bigay lang kasi so sayang lang di ba)... now if sum1 is kind enuf 2 provide me with the dimensions.... :wink:
btw mdf or plywood? :roll:
- 109
November 24th, 2002 06:09 PM #10anton, no apologies needed buddy. a tip, minimal power lang bigay mo sa sub para di malunod ang mga seps mo. mdf ang gamitin mo. dimensions, maybe u can try going to the kicker site and ask them for the specs. they would be the best place to go for your inquiry about the box
high idle RPM at engine start
