Results 1 to 4 of 4
- Sep 2005
- 8
May 4th, 2007 06:57 PM #1HI. I have 2002 model Cerwin Vega Hed subwoofer and Im going to install it in my 2005 Honda Civic what box size can you guys recommend in sealed box wherein its manual states 1.4 cubic feet? do I have to follow the specs in order to boost the power and what amp to use? HELP........
May 4th, 2007 09:45 PM #2
- Sep 2005
- 8
May 7th, 2007 11:44 AM #3if I use a ported box would it be much stronger, and can you give me an advise on its boxs size, from width to length. thanks.
May 11th, 2007 01:19 PM #4
Yes it's possible. But to achieve the correct frequency response and port dimension, frequency generator is required.
From the speaker parameters, box dimensions can be calculated. The port can be determined by trial and error method with the use of a frequency generator to simulate the frequency response of the enclosure.
Post your speaker model or type. If possible, include the parameters (i.e. Fs, Vas & Qt). If not available, search in the internet.
Has anyone of you tried buying or installing front bumper that's made in taiwan (yung...
