Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
    #21
    ^^ sir gusto niya lang daw kasi tumunog, not necessarily a good set up.
    pero if you want some quality on them, then ok yung sabi ni userfriendly.
    Oct 2007
    #22
    mga sir, ako rin patulong din.naguguluhan po ako.
    ito po mga balak ko bilhin
    Head unit: Pioneer DEH 5050UB or DEH 4050UB(bibilhin ko na by next week:banana1
    good seps; ?pinagiisipan ko pa!(anu pala maganda)
    good sub mga 12": ?mga 3 budget
    good amp: ? mura pero oks
    btw ride ko ESi, habol ko po SQ na may boom-boom.(mayron po ba nun).
    ty po
    #23
    Quote Originally Posted by EGcoolmhan View Post
    ty po
    sa seps, i would recommend polk.. the best for seps IMO pero kung mid class naman ok na din yung lansar. its not expensive pero good for SQ.
    if SQL ang habol then go 15"... try phoenix gold 15" then ported. kung may budget, get the L5 kicker.
    amp... hmm if budgeted, v12 fenton or jbl will fit in nicely. extra cash? go for RF
    Oct 2007
    #24
    Quote Originally Posted by archie123456789 View Post
    sir archie, ok lang ba kung straight JBL ako? like this one.
    seps: JBL GTO607c or JBL C608GTI MKII
    sub: SQL?(sir mayron ba talaga ganito? diba SQ at SPL lang)
    (habol ko talaga clarity ng sound na may boom-boom)
    - sir most probably 12" lang na ported yun lang po yoko malakas msyado
    amp: JBL PX 300.4
    ginawa ko lang po yan as a prospect setup ko.
    how about TARGA seps and then JBL subs and v12 amp(taiwan)?
    any recommendation mga sir!tulong po by nextweek papagawa ko na po!
    #25
    SQ -- sound quality
    SPL -- boom boom
    SQl -- mix of both (pinakamahal na setup)
    sure you can go full jbl pero IMO mas ok to get other brands with the same prices... jbl are ok in all aspects but better in amp (bang for buck)
    lansar are good in mid range and tweeters
    PG are good in subs.
    its to your own taste ang sounds... so in my case, i like sounds of the SQ with a pinch of more boom boom.
    targa are the best for bang for buck seps
    subs of jbl... hmm... not really to my taste. i like the PG boom better.
    jbl delivers good boom but not much umph than the PG.
    v12 amps are very good as i learned when i was schooled by my cousin.
    just look at the knobs (dapat yung itim, not the grey ones)
    Oct 2007
    #26
    SQL...wow mahal pala yun.
    SQ lang na may boom boom nalang basta malinis tumunog kahit malakas ang volume at mganda ang boomboom niya oks na sa akin yun.
    btw, gusto ko lang ibudget dito sa sounds eh 17k pababa lang kasama headunit.yoko masyado pricey kasi di naman ganun kaganda ang car basta may sounds lang na maganda tumunog.
    anyway sir salamat po sa opinion po niyo, nalinawan na ako.mganda daw sola-baric L5 or L7 yun lang lam ko. at targa na siguro na 3 way seps.ok na yan.
    #27
    L5 and L7 are very good for the SPL setup, matigas ang bayo nun.
    pero its too expensive for me yung kicker L7.
    sa budget mo, talo ka na kung kasama HU dun... baka hindi kayanin yung L5 kicker. i think aabot ng 7k yung HU model na yan. wiring, labor, power supply, box... go for v12 amp, targa seps, and jbl or PG subs. baka umabot sa budget. hayaan mo na yung rear speakers mo na stock.
    bridge 2 ch sa seps and 2 ch sa subs... minimum of 500watts rms. let the HU power the rear.
    hope this helps and good luck!
    Apr 2008
    #28
    Quote Originally Posted by userfriendly View Post
    Both would do. Its really a matter of taste and budget. Seperates will offer more flexibility in installation. You can choose where to put the tweeter. Generally, it has a better crossover than the coaxial.
    However, some high end coaxials will sound better than low or midend seps. A coax is also cheaper than seps (provided its from the same manufacturer and series).
    Installation is key. A poorly installed high end setup can sound bad. A cheap all Targa setup done correctly can sound amazing.
    If all you want is sound for the road, then a decent HU and coaxial speakers is perfectly fine.
    +1
    i agree on this insight...
    Oct 2007
    #29
    thanks po sir..ipon ipon muna ako para sa subs gusto tlaga yung L7 or L5.gusto ko lang talunin ng bayo yung kapit bahay namin, yabang niya konzert naman subs niya.lagi niya binubuksan trunk niya pinapakita pa sa akin.
    #30
    nakooooo, sabi na gusto mo SPL than the SQL setup...
    then much better to go L7 on this and have MTX or RF amps on it... maximum boom boom. yayanig mundo mo sa L7. :bwahaha:
    Oct 2007
    #31
    oo sir, SPL setup na ako atleast mahilig din boom boom dad ko pag ginamit kotse ko eh mamumukhang binata ulit..gusto ko lang yanigin yung kapit bahay namin na mayabang. kya go for L7 na or L5 kahit mahal pagiipunan ko para mapahiya siya.hehehe
    btw sir salamat sa mga inputs mo..
HELP! from a car audio newbie
