Results 1 to 10 of 21
- Jan 1970
- 164
June 6th, 2003 05:36 PM #1I want to know which would be better.
My HU says it has 22w minx4chn (4ohm)
Is this enough to power front seps (still need to buy these) and rear 5.5" coaxials. The front seps will probably be small 4" and tweeter so I can use the factory mounting.
I don't plan on playing anything too loud. I'm just going for quality especially for long durations (on long road trips).
Eventually I'll also get a sub and I can use the pre-outs of the HU.
June 6th, 2003 05:43 PM #2
external!
decent sounding na yung amp sa HU mo. tutunog sa tutunog sya pero pagdating sa high volume, parang mejo distorted na yung labas ng music.
yung akin, 4x50w HU ko, nabibitin ako sa tunog ng seps ko sa harap eh kaya i'm saving up to buy a fenton amp.
my 2 cents, HTH
- Jan 1970
- 164
June 6th, 2003 05:54 PM #4I'll probably get a fenton amp for the sub. I'm thinking of getting another one also for the seps and rear fill but for now sa HU na muna. I'll test it siguro with an amp...I'll probably like the way it sounds and get the amp....then I'll find something else to change again....hehehe:twisted:
June 6th, 2003 11:25 PM #5
you can power your front seps and sub with your 4-channel amp and the seps at the back be powered by the hu.
- Jan 1970
- 164
June 17th, 2003 01:46 PM #6I got the seps na and installed them sa HU muna. Ok naman ang sound pero bitin pa ang bass. Need to work on that next.
What happens when you don't use the HU to power any speakers and naka amp lahat. Is this bad for the HU or not?
- 19
June 17th, 2003 02:38 PM #7If you don't use the HU to power any speakers and naka amp lahat I think and IMO that'll be good kasi your not using your HUs built-in amp thus di sya masyado mag-i-init. Plus you'll get a more cleaner sound if your speakers powered by an amp.
Regarding your lack of bass try getting a bigger seps say a 6.5 inchers and not a 4 inchers or if there's an adjustments sa HU mo you can play around with it till you get the bass you want.
HTH :D
June 17th, 2003 05:29 PM #8
external. normally, external amps are more powerful than hu amps, na merong limited range lang.
- Jul 2003
- 14
July 11th, 2003 06:48 AM #10Definitely go external amp. Ano ba ang seps mo and coaxials mo? Ano ang rms power? Kung 50 rms yan get an external amp close to the rms power ng speakers. 40-75 watts pwede na. Dont go close to the max power ng speakers.
Xiaomi E-Car
