It would be best that you use a processor with active crossovers together with the 4-channel and mono amps. The HU should be just be used as a signal source. Then use the tweeters and a pair of mids powered by the 4-channel amp thus coming up with a 2-way active system. If you want to come up with a 3-way active system, use the other pair of mids or a bigger mid-bass (8 inches) plus another 4-channel or 2-channel amp.
