Results 1 to 16 of 16
    Jun 2012
    guys, nagpapatulong lang friend ko. gusto nya ng head unit na may video, gps, at kung pwede with camera. yung sa casa AVT. 50k without camera pa yun.
    baka may alam kayo sa labas na nagiinstall na maayos. as in fit. para sa 2013 vios talaga. na sure rin sa quality. maayos gumawa. maraming salamat.
    Does he have the replacement faceplate for the 2013 VIOS to fit in the 2DIN headunit? If he has, he could use practically any 2DIN headunit with touchscreen. Downside, the steering wheel controls would become useless...
    Aug 2010
    Quote Originally Posted by dct View Post
    Tell him to drive to Banawe and ask there. Prices differ depending on how great he is in haggling. CASA prices are ALWAYS expensive. Markup nila is something like 200-300% kaya
    Jun 2012
    none sir. hindi po ba kaya ng banawe yung steering wheel controls? and does banawe have this panel?
    Quote Originally Posted by jhnkvn View Post
    yes sir. laging mahal sa casa. pero naisip ko lang na bago kasi yung vios, duda ako kung may mahanap na agad na swak para sa new vios, at kakaiba rin kasi head unit ng vios e. parang lagpas sa dashboard. meron na kaya sir?
    I have stuff installed by Jemson: https://www.facebook.com/pages/Jemso...ref=ts&fref=ts
    But I order from Roman: https://www.facebook.com/roman.lao?ref=ts&fref=ts
    Some of Roman's HU's can even work with Toyota steering wheel controls
    Aug 2010
    Dashkit panel, meron naman Banawe. Not sure if stocks are numerous though owing that it usually takes a few months after launch for accessory "stocks" to stabilize.
    Meron. All you need is a 2DIN head unit and a headunit panel for it. Basta makakuha ka ng panel, you can fit any universal 2DIN head unit in it (ex. Pioneer head units). However, all-in-one OEM-spec'd head units much like FlyAudio or AVT probably won't have models released yet. Probably nagmamadali pa sila sa pagdesign or something
    Jun 2012
    ok naman po sir? with regards to Roman's product and installation of Jemson?
    concern ko lang ay baka wala siyang pang new vios. will try to contact him
    Jun 2012
    so ang kailangan hanapin ay yung panel?
    meron na sir ang AVT pero ang mahal e. 50k without camera pa. baka merong mura outside casa na OEM spec'd
    Aug 2010
    For the universal 2-DINs such as Pioneer, yes. You need a standard 2DIN dash kit panel for the 2013 Vios. Problem with universal 2-DINs like Pioneer is that they're won't have GPS. You'll get the video though.. plus you can install a separate rear-view camera for most models.
    For the OEM spec'd, you don't need to find dash kits na. They usually retail around 30k sa Banawe. No idea if that's with or without camera though.. I believe it's without.
    Jun 2012
    i see. prefer kasi ng friend ko ay yung OEM. 30k is a big difference. ok na siguro yun. but would you know if there are specifically for the 2013 vios?
    Jun 2012
    pag dumeretso ba sa winterpine, mas mura ba? if so, gano kamura? may warranty pa rin di ba?
    check mo na din iyong growl audio. meron silang package na kasama na iyong hu, gps, dash panel, etc for hyundai, mitsu, honda, toyota, etc
    iyon nga lang i'm not sure about its quality sound reproduction or its durability
    Aug 2010
    I haven't heard any kits for the newly released Vios at the moment.
    And yes, I believe if pinakabit mo sa Winterpine, the warranty's still in-tact. But I'm not sure if this is limited to Mitsubishi Quezon Ave. only (who partners with them) so best to ask first. I wouldn't worry much about the warranty. You aren't splicing any wires after all so dapat electricals is still in-tact.
    Wala pa naman ako naging problem sa mga tinda ni Roman. Si Jemson minsan may backjob but he has been doing work for us for two generations already. Namana ko pa siya sa father ko.
    Roman also has a rear camera that is a direct replacement for the common Toyota license plate lamp. If the vios uses the same license plate lamp, direct fit na siya.
    Jun 2012
    yun din naisip ko e. because of our montero. hehe. AVT kasi is under winterpine e. i'll try to check. thanks sir
    thanks sir. pa-try ko rin po to
    Feb 2005
    sir,try nyo po growl audio baka meron na sila oem.search nyo sa sulit.com.
head unit for 2013 vios
