Results 1 to 4 of 4
- Dec 2008
- 6
December 7th, 2008 05:51 PM #1guys, tanong ko lng po...anu mas mgnda 1 sub or 2 subs...JL audio gusto ko..gusto ko ung mtgal ung gapang at mlkas sa lbas ung sub...thnx 4 d info...
December 7th, 2008 06:01 PM #2
san ilalagay? single sub na tama yung size ng box pero kung kaya 2 sub ok din. pero jl is known sa mga SQ. you might want to check other subs na usually na ginagamit sa streetbass.
- Dec 2008
- 6
December 7th, 2008 06:10 PM #3sa corolla big body...ask ko lng what is SQ?...anu2 po ba mga subs sa streetbass
- Nov 2008
- 123
December 13th, 2008 06:07 PM #4Yong sa gusto mo na output sa bass mo..magdepende sa design ng Enclosure mo..Brother ko Meron dalawang 15" L5 KICKER in minimum seald enclosure (seald coz space was a problem) malakas siya pero yong sinasabi mo na gumagapang yong bass(low frequency) hindi makukuha masyado sa seald enclosure(lalo na maliit pa yong enclosure)..so, nagpalit kami ng ported enclosure (5 cubic/ft tuned to 33-34hz with 1 sub in it masganda ang hataw at gumagapang ang bass)..Maseffecient pa ang isang sub na sakto sa measurements sa enclosure kay sa dalawa na halos hindi magkasya sa baggauge compartment..Sa JL ang cheapest nila maliliit yong RMS power rating..meron silang W7 sobrang mahal naman...Coz if you want more BASS you need more power from your sub, bigger enclosure (tune it low) and Bigger amps.. Good luck!
Ported enclosure 5 cubic/ft
Seald enclsoure 2.5 cub/ft each compartment
high idle RPM at engine start
