Quote Originally Posted by xtian_joyaxx View Post
That's the big question..you need to measure how much space (max space) dahil ang 10" pagnasa tamang box design it will still be loud..
(Im talking a Ported enclosure).
Im sure your thinking dahil 12" malakas na..it is not the case sir dahil pag ang montero mo ay limited ang space at isaksak mo ang 12" not in proper enclosure madisappointed po kayo sa outcome (pangit po ang response ng bass ninyo)...
IMHO sa single 10" po ussually ilagay ko yan from 1.50 -1.75 cub/ft internal vol. (after displacement ng SUB at Port..so you need to build a slightly bigger enclosure)
For single 12" po I would really recommend minimum 2 cubic/ft to 3 cub/ft max internal volume after displacement..
kung magseald kayo..it is up to you..(ussually itong ang recommend ng mga installer para lang makabenta)..pero it will give a you flat response ng bass..
Hope this will help..sir..
thanks for the info sir xtian!
yun din ang sabi ng ibang shops na napagtanungan ko eh... yung iba sabi nila hindi kaya, yung iba sabi kaya. yung iba naman sabi they have to re-measure the space sa likod ng montero.
sa sealed daw walang problem, yung ported ang kaso eh. pero syempre sa ported tayo para hindi sayang ang de dose diba? hehe.
