Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Oct 2007
    hi! ask ko lang sa inyo kung good setup na ito...
    JVC KD-BT22 head unit (stock HU ng montero sport)
    DLS-B6A separates
    stock mitsu coaxials sa rear
    Sound Magus C160 4-channel amplifier (to power the DLS and the sub)
    JBL GT5-12 subwoofer enclosed sa ported computed box
    sound deadening
    suggestions are welcome...
    thanks po!
    ano ba kotse mo? montero?
    if you can get yung mga older models na alpine na may time alignment get those! time alignment really makes a difference while tuning the speakers
    you can run the front components and the sub in the back as long as the sub box is properly ported and the speakers is tuned.
    Usually good components need each speaker to have its own channel.
    So you need 2 amps 1 4 channel for the components and then 1 single/mono amp for the sub
    i have this set up on my car and maganda talaga yung sound medyo matipid pa sa speakers coz harap yung components and 1 JL10w6 sub sa trunk
    Oct 2007
    Quote Originally Posted by Dranom View Post
    yup sir. montero ang sasakyan ko. okay sana alpine but i want to use the stock head unit eh...
    anyway, yung front seps ko po would be powered by a 4-channel amp. pati yung sub bridged connection din from the same amp. yung coax sa likod will be powered by the HU. so in a way meron din control per speaker yun nga lang hindi per channel kundi per pair. tama po ba? :D
    Quote Originally Posted by sag0 View Post
    Helloo..gagana yan sir..kaso interms of sound clarity in high-volume ma unang magdistort( overdriven ang HU) ung mga speaker powered by the HU due to low power lang HU mo..may possibilty po hindi mo mamalayan ang likod at sunog na ang rear speaker dahil sa lakas ng front end..
    Oct 2007
    Quote Originally Posted by xtian_joyaxx View Post
    hi din sir!
    kayang kaya nung DLS ko sa harap yung HU... and you're right yung likod na speakers ang nagsusuffer.
    hehe sa tingin ko nga sir parang basag na yung tunog nung stock speakers sa likod eh... lakas ko kasi magpatugtog kahit wala pang amp.
    nangyari din saken to mga idol. may seps ako sa front powered by amp tapos subs ko mono amp. bale rear speakr sa hu lang. ayun sira na ngaun ung rear speaker.
    Sir xtian,
    Question lang po. Medyo pareho po kasi ang naisip kong setup kay Sir Sago. Hindi ba pwedeng ma-compensate ang effect ng distortion sa rear speakers by adjusting the fader para mas malakas ang tunog sa front speakers (which are powered by the amp)?
    pang FILL in lang nman yung rear speakers eh
    as long as ok yng speakers (front components) youll be fine
    like i said sa kotse ko i have a set of focal components up front and a 10" sub in the back and it sounds pretty good IMO.
    its better to run the speaker per channel so the SQ wont suffer
    just buy a good affordable amp for your sub and youll be fine.
    also malaki nman kotse mo so kasya nman 2 amp
    Quote Originally Posted by kapitan_dukot View Post
    Sir xtian,
    I knew sombody will pop this question..hehehe..Pwiding pwidi po sir..dependi kung gaano ka ganda ang "fader" mo sir dahil may ibang stereo hindi maganda ang pagkagawa..tulad ng mga Generic amps yong x-over cut-off hindi mo maiitindahan kahit anong adjust halos ganun pa rin ang tunog...
    Salamat sa response sir. Hopefully maayos naman ang stock head unit ng Montero... tapos yung amp na gusto kong gamitin DLS naman so hopefully okay din...
    Oct 2007
    Sir xtian,
    sir kap! san ka magpapagawa? medyo iba na ang gagawin kong setup eh. i want it as clean and as loud as possible pero within budget hehe. may i ask anong mga ilalagay mo? :D
    Sir sa set-up po ninyo..a pair is enough for SQ set-up but if want loud and clear..dalawa sa harap at ang stock na speaker ninyo sa likod it is not enough..
    You need to have these!!
    Or this one..
    Oct 2007
    Or this one..
    grabe namang dami nun! hehe medyo loud and clear (and clean looking) lang and hindi yung abot ng limang kantong loud and clear :D
    Sir Sago, nakapagpakabit na ako sa Winterpine ng seps (front), coax (back), at amp. Nung una gamit ko yung luma kong RF na sub, pero since nabenta na yun (just last week), nagpapagawa ako ngayon kay Mickey ng OEM-look na sub enclosure para sa likod. Setup details so far are:
    Head unit: JVC KD BT-22 (stock)
    Amp: DLS XD40
    Front Speakers: DLS XSC62
    Rear Fill: DLS 226
    Sub: still choosing between Image Dynamics XTC104, Image Dynamics ID10v3, or JL 10WOV2
    Oct 2007
    Amp: DLS XD40
    Rear Fill: DLS 226
    nice amp sir! how much yun? hehe...
    talagang 10 inches lang mga list ng subs mo ah. sabagay so far sa mga napagtanungan ko yun daw ang pinaka kasya sa montero natin sir eh... ayaw mo din try ang 12? hahaha ako nagtatanong pa kung maiinstall ang 12". tigas ng ulo ko gusto ko de dose :D
    grabe naman yung pinto na yun! OA na! hehehe!
    That's the big question..you need to measure how much space (max space) dahil ang 10" pagnasa tamang box design it will still be loud..
    (Im talking a Ported enclosure).
    Im sure your thinking dahil 12" malakas na..it is not the case sir dahil pag ang montero mo ay limited ang space at isaksak mo ang 12" not in proper enclosure madisappointed po kayo sa outcome (pangit po ang response ng bass ninyo)...
    IMHO sa single 10" po ussually ilagay ko yan from 1.50 -1.75 cub/ft internal vol. (after displacement ng SUB at Port..so you need to build a slightly bigger enclosure)
    For single 12" po I would really recommend minimum 2 cubic/ft to 3 cub/ft max internal volume after displacement..
    kung magseald kayo..it is up to you..(ussually itong ang recommend ng mga installer para lang makabenta)..pero it will give a you flat response ng bass..
    Hope this will help..sir..
    Dranom:grabe naman yung pinto na yun! OA na! hehehe!
    Hanggan tingin na lang tayo sir at makisabay sa kanila..hehehe
    ^^^ kya nga! pro di malinis tinginan though.
    ska ano nmn kya SQ non?
    Oct 2007
    thanks for the info sir xtian!
    yun din ang sabi ng ibang shops na napagtanungan ko eh... yung iba sabi nila hindi kaya, yung iba sabi kaya. yung iba naman sabi they have to re-measure the space sa likod ng montero.
    sa sealed daw walang problem, yung ported ang kaso eh. pero syempre sa ported tayo para hindi sayang ang de dose diba? hehe.
    Sir nabili mo na itong GT5 12"... ano yong sinasabi mo na computed box? ito ba yong ready made na box ng JBL? Sa ported sir you will not be dissappointed kung marunong ka magtune ng "port" kung anong frequency ipapalabas mo..efficient po talaga ang ported enclosure.. pero kung butusan mo lang ang enclosure at hindi mo alam ang kung anong frequency ang ipapalabas sa enclosure sayang lang po ang pinagpaguran nyo po.. check this thread dahil parehas yata kayo ng Sub.. http://tsikot.yehey.com/forums/showthread.php?t=60346
    Dranom: ^^^ kya nga! pro di malinis tinginan though.
    Sa ganito na set-up po sir mahirap e-achieved ang sound staging sa loob ng sasakyan but if your talking about sound quality, clarity and effeciency even at very high volume..ma achieve po sa set-up na ganito..ito po ang SQL. lalo na nakatambay ka lang at sa labas nakikinig dito..(sa shell at pa coffee-coffee..hehehehe)
good setup?
