Results 1 to 16 of 16
    Aug 2011
    Any good reviews about it?
    Aug 2010
    Very good separates for its price range especially the entry-model EV602.
    Jun 2010
    sa subs, value for money din sila. gapang kung gapang pero hindi butas ang bulsa mo.
    Quote Originally Posted by jhnkvn View Post
    x2 with this one...heard it paired with 9887 WITHOUT amp and grabe, bang for the buck!
  5. #5
    Kinabit ko sa BMW M3 last tuesday, pasok agad, no other modification required, at that wattage level nya, very amazing kase slim and lightweight pa, di kagaya nung ibang speaker na ka-level nya na mabigat na, mahirap pa i-mount kase malalaki yung magnet at malalim yung mounting depth, yung firland 602 seps ng firland, di problema ng installer ang mounting location, lalo na sa M3 na ang speaker is attach on the sidings cover mismo.
    Aug 2011
    Okay lang po ba na stock yung rear speakers para mabuhos yung budget sa amp, seps and sub?
    Quote Originally Posted by GTS925 View Post
    yes sir, tama po yan
    Aug 2011
    Malaki ba difference ng EV602 sa EV622 in terms of sound quality?
    Aug 2009
    Nag inquire ako sa firland-audio about sa amps and speaker..eto po qoutation ni sir kenneth sa akin..
    XL2000D=22,500
    XA480=11,200
    EV650=12,800
    gusto ko pa sanang itry firland audio,dagdag sa mga nabili ko kaso mahal pala..heheh
    May 2011
    mga experts tanong ko lang paano ba setup ng gumagapang na bass? nasa box or subs naka depende?
  11. #11
    Nasa box design po mostly, the port tuned from 37hz to 45hz, and you have to made harder inclosure without air leaks except the port to get hard hitting bass, if you want to feel the bass up to the next block, you have to get serious sub woofer, a 18" and a 2000 watts power handling is a good choice, syempre, along with the serious power supply.
    For example:
    http://a8.sphotos.ak.fbcdn.net/hphot..._5234539_n.jpg
    Quote Originally Posted by wendellburug View Post
    XL2000D=22,500
    XA480=11,200
    EV650=12,800
    you can get those at tsikot shop, same price plus free sound deadening , 5 sheets worth 2750
    Sep 2011
    Local ba ang Firland? San po ba gawa toh?
    Dec 2011
    I've never heard of Firland Audio before, all I can say is mas mahal pa sa mas kilala at higher end for the same power range. Comparing the price of my Alpine MRX-M100 (600W RMS * 4ohms and 1000W*2ohms) vs Firland Audio XL2000D (700W RMS * 4 ohms and 1300W * 2 ohms, "sana nga!". Most amplifiers are overated so that consumers will buy their product but not the Alpine products which is under rated according to test and comments of users, and so puts out more power than what is says on the box. MRX-M100 actually produces over 1200W * 2 ohms and sound quality is amazing, so I'll stick with my Alpine!
    I just had my car audio set up using an all-Firland system, and my initial impression is wow! Total bang for the buck! I don't like spending a lot of money only to be disappointed or to be underwhelmed. My Firland system has exceeded my expectations in car audio at a very reasonable price. The voices and instruments are very clear, and the amps are doing a good job powering the speakers. Firland Audio's quality is top notch considering it price.
    Highly recommended brand.
    Feb 2009
    Quote Originally Posted by palonmar View Post
    but you should also know bro, xl2kd's are 1ohm stable with 2000wrms.
Firland Audio
