BTW, bat ung tweeters sa rear di affected? Bale ung wiring config ay yung amp ang nagpopower sa 2 sets of seps and sub. Ok po ba ito o kelangan ko pa ng 1 pang ampli? Thanks
That is 3 channel setup. Thats good, because the 3 channel setup is advantage to your sub you can adjust the subwoofer volume by tweaking the "gain control". If your amplifier has a variable low-pass crossover, you can adjust the crossover point, too.
Can you tell me exactly how they wired your system. You see, using an underpowered amp is more damaging than an overpowered one, and may result in 'clipping' where the amp runs of steam trying to drive the speakers.
I NEED TO KNOW THIS:
1. Where did you mount the seps?
A. Do you have a "passive crossover" on the woofer and tweeter?
A passive crossovers are incorporated into your tweeter leads and woofers in a separate module for each channel, usually it connected after your amp.
2. Are you using amp on the front & rear speakers or you powered only with your H.U? Which one w/ an amp?
3. Which tweeter that it burn? Are you using an amp on this tweeter?
