Results 11 to 13 of 13
October 7th, 2011 04:08 PM #11
Best option is to still go for a secondhand CDA-9887.
#2 option (will upgrade in the future) is to just get the CDA-117 (as you like it brand-new) and upgrade to the PXA-H100 in the future.
#3 option (will not upgrade) is to just get any mainstream Pioneer unit. Wala naman masyado difference in capabilities and internal components so choosing is (jokingly) based how much you like its appearance.
Personally, I believe time alignment is very important. A more hassle way to do this is independent L/R EQ like how those old IASCA/EMMA champions used to do it in their day. Like I said, once you get T/A and your phrase correctly, majority of your problems are gone.
As for the lack of bass, madami pwede culprits. Since I'm not sure how you define bass (most people perceive bass as somewhere 50hz to 250hz where 250hz is the "macho" sound of the male voice), this might be due to the:
1. Crossover. Maybe Jon crossed the midbass at 100hz and as you don't have a subwoofer, so there's a hole from 20-100hz. This is HIGHLY unlikely for experienced installers.
2. Phase. Does the midbass look like it's "lost?", if it isn't focused or it's hard to locate, it's probably a phase issue.
3. Product defect. Although remote, there's also that possibility that the midbass is a defect. My Focal 3KRX3 had a defect initially and I had it replaced, before replacement all I hear was very audible distortion. The chances of it is very remote though.
4. Level-matching. Again, it's highly unlikely for experienced installers to oversee this. But it does happen. And as I do not know how the setup is: is it passively bridged? Is it active? If it's passively bridged, then #4 is automatically invalidated. If it's full-active, the midbass is probably not level-matched with the rest of the system hence it's -dB lower.
5. Perception of bass. I had times when people sit in my car and say "hindi ba dapat BOOM BOOM yun bass? Bat ang hina?"
Again, these is just one of those numerous possibilities on why. Other possibilities are: faulty RCA kaya? etc. For most cases, I'd recommend you check #2 and #4 first. #5 is also a common mistake on the user since there was a time when I switched my subwoofer off, cut my midbass at 100hz, and the first thing I exclaimed was "shet, nawala bass ko!"
October 8th, 2011 10:01 AM #12
October 8th, 2011 07:24 PM #13
Just got home from Tsikotshop. Thanks Jon sa pagtuno mo ng sound system ko. Ok na ulit. After kasi ma install ng Maspro yun Head unit ko humina yun rear speakers and nag karoon static. Defective pala yun RCA kaya kulang yun tunog ng rear speakers. For the static naman he reduce the ground cable yun na nawala na static. Ngayon ok na yun sounds ko. Next investment is subwoofer. :P
Again Thanks Jon and tsikotshop for a Job well done.
I just imagine it's a manual especially at low speeds or while maneuvering on inclines. Nature of...
(2023) Ford Territory
