Results 21 to 30 of 115
January 28th, 2017 12:34 PM #21
Page Not Found | Facebook try this link... lhen castillo
cheap dashcam... meron pang rear view mirror na dashcam....
- Apr 2017
- 2
April 21st, 2017 04:39 PM #22
April 21st, 2017 04:42 PM #23
- Jun 2017
- 511
August 27th, 2017 07:16 PM #24Hi, everyone!
I'm new to dash cams; just thought of getting one. I'd be grateful if you could answer my question: Do all dash cams continue to record even if cars are turned off?
Thanks in advance
August 27th, 2017 07:19 PM #25
Dash cams don't usually record if the car is off (and thus no power), but you can set up your wiring to have power fed continually to your dashcam to have 24/7 recording.
Just be mindful of the heat which could prematurely kill your dash cam, and make sure your installation is done very well in order to avoid any electrical mishaps.
- Jun 2017
- 511
August 27th, 2017 07:36 PM #26
- Aug 2017
- 232
August 27th, 2017 11:34 PM #27Hi. Please help me out. Should I get the VIOFO A119 or the DDpai Mini 2 for my first dash cam? Is it reasonable to spend a bit more for the Mini2 or are the specs of the A119 good enough?
Thank you!
- Jan 2008
- 4,726
August 28th, 2017 12:10 AM #28
- Jan 2008
- 4,726
August 28th, 2017 12:12 AM #29
August 28th, 2017 11:28 AM #30
Better to get power from a powerbank for your dashcam and hardwire the powerbank to charge when the vehicle is running ... maybe there are dashcams with built-in battery ...
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
