Results 1 to 10 of 18
December 1st, 2005 06:55 PM #1
Went to Megamall to check Targa and they also offered me Crystal Audio. I saw lots of thread saying Targa is bang for the buck. Here goes:
Crystal
CXE (200W) - Php 6,000
Bizark Amp (800W) Php 18,000
Amp Kit Gauge 4 - Php 1,600
CMP x 12 (Subs) - Php 15,000
Holder blah blah - Php 600
TOTAL - 41,200
Targa
Targa Sub 12" - Php 2,600
F4100 AMp - Php 9,100 (SALE: Php 6,500)
MX 259 (5", 120W, 2-way) - Php 900
X 653 (6.5", 150W, 3-way) P1,200
Anu masasabi nyo?
Eto sabi sakin:
No need to amp the rear, surround naman yun (same concept home theater). I find it logical, even my surround isnt that powerful...
Rear speakers can be directed to HU
For the Crystal setup, Fenton will do but Bazark is better
May single/dual coil pa silang mentioned, 4 and 8 ohms
I'll edit this post if i remember other stuff he mentioned.
December 1st, 2005 07:09 PM #2
IMO, scrap the rear speakers, get a good pair of separates up front, a four channel amplifier, a good SVC or DVC (DVC prefered). Rear speakers are really optional since the highs and mids will come up front and the lows will come from the subs. Rear fills will supplement the subs.
Crystal or Targa?
For me its a matter of budget, if you have money to burn go get the crystal Subs and separates, as for the amplifier I suggest you get a 2nd hand, for me its the best bang for the buck, you can search kotseaudioclub.com, dami dun nagbebenta ng 2nd hand audio parts....
Amp kit for 1600??? Bili ka nalang sa Raon, but am not sure if they have a 4-Gauge wire. Try looking for that in banawe or araneta
December 1st, 2005 07:28 PM #3Originally Posted by ILuvDetailing
For AMP, i've read a thread here regarding Alpine V12 (fake) and Fenton 4100. What do you think is better option? Pwera sa Alpine V12 fake and F4100, meron pa bang ibang ok?
Meron akong nakakabit na 6x9 na Pioneer sa likod... nu gagawin ko dun?
And also i want a decent space in my trunk? What should be the proper way to do it w/o sacrificing the quality? I also don't know what is ported and sealed enclosures.
For the Amp Kit, does that include Engine compartment grounding like those Hyper ground kit and alike?
How about crossovers?
December 1st, 2005 07:39 PM #4
Targa is not bad for budget setups, but Crystal sounds better for me, it also depends on the tuning.
I'd go with the V12, specially with the newer models comming out with good enough power to provide some ommphh... but if you can source a 2nd hand amp like an alpine, mtx, infinity, etc. that would be better...
Check the amp kit. It should have a pair of RCA, ground wire, power cable, terminals, remote wire, fuse, fuse holder. you can use the your 6 x 9s if you can tune it so that only lows will come out much better.
if your concerned about space go sealed.
newer amplifiers already have built in crossovers... some older model amps don't you have to check this when buying a 2nd hand amp... do a searc here, it has been discussed many times.
December 1st, 2005 07:49 PM #5Originally Posted by ILuvDetailing
I asked the person there regarding Targa - Japan tech, made in Philippines, components are from China... So Targa is ok?
Regarding the amp, so using fake Alpine V12 is ok? CHoices as per your advice: V12 or F4100? Panget ba yun Fenton, base on your exp.?
What do ineed to check when buying 2nd-hand amp? 1KW ok na yuN?
What's the difference between sealed and ported aside from space consumption? How about sound quality? Where should it be placed? SHould it be facing front (papuntang driver), back (palabas ng trunk), or a specific angle?
Meron pa sinasabi sakin gapang paloob or palabas, what's that?
Btw, thanks for ur tips hehehe
December 2nd, 2005 01:25 AM #6
I ditched my rear speakers na din for the Pajero. For the Benz, the rears are powered by the HU and provide some rear fill.
I'm running a 12" SVC on the Paj, a 10" SVC on the Benz. Both are powered by 'fake' Alpine V12 MRV-705's.
I suggest visiting Jeff Tan's shop along Araneta Ave. if you are a bit budget conscious.
If space is a concern, stick to a 10" sub as it requires a smaller sub. If you need more boom, go with a ported box. I got mine at Jeff's for Php 1,800.00 including the quick release connectors.
December 2nd, 2005 06:51 AM #7Originally Posted by OTEP
Follow-up questions:
1.) What's SVC? 10" sub, d bako mabitin nun? And besides they have 8, 12, and 15s. How much is the fake Alpine V12s? Sabi sakin friend ko, check daw amp dahil namamatay pag naginit.
2.) I'm still confused kung anu and para san ang sealed and ported box. Meron pa akong nakikitang ABC box na dun daw maganda ilagay targa subs...
Lastly, Targa din ba gamit mo? THankss!
December 2nd, 2005 10:12 AM #8
it depends on what type of music and what kind of setup habol mo. for me, adequate na ang 10" sub for the low frequencies in my type of music (R&B/hiphop/alternative). sealed boxes have a wider range of frequencies na kaya, ported naman maganda at certain frequencies but not as flexible as sealed.
Tsikot Member Rank 3
- Sep 2003
- 786
December 2nd, 2005 11:26 AM #9Originally Posted by OTEP
December 2nd, 2005 11:29 AM #10Originally Posted by bongliza
Originally Posted by ssaloon
Traffic!
